10 spoke ss rims on a 95 z
The wheels fit in the fender wells the same as they do on the newer cars. The only difference is the rear hubs on the LT1 cars are a tiny bit bigger and as such need to be sanded or the inside of the needs to be, otherwise they won't fit over.
As stated they fit as they would on the newer cars. You will need to grind/sand hubs on the rear rims. As far as rubbing, I have 275's all around and no problem.
https://www.camaroz28.com/forums/sho...d.php?t=596366
This is a post about the same topic (I posted at the end) and I have my car domain site with a little bit of information on the grinding required. It will take less than a minute on a dremel per side. So it is not a big job.
