A.I.R tubes question,,
Old Apr 12, 2008 | 08:30 AM
lordmetalz28's Avatar
ok where doing headers today. where wondering to eliminate this air pump garbage can we just rip it off and leave like that or is there something else this pump feeds that we have to worry about. or iis it just soley used for the exhaust manifolds.
Old Apr 12, 2008 | 11:26 AM
rik89gta's Avatar
You can remove the air injection system as long as emmisions aren't a major concern. The air pump basically routes air to the catalytic converter to help it burn off unburned emmisions. I removed the air pumps on two of my tpi cars. However if You remove the air pump You'll need to get a longer sized serpentine belt.
Old Apr 12, 2008 | 11:39 AM
Cat has been long removed, emissions is not an issue, and its coming off. also my serpintine belt dosent have anything to do with my air pump,,MAYBE cause i removed my a/c as well so thats not a problem either
Old Apr 12, 2008 | 02:39 PM
Rice Killer87's Avatar
You wont have a serpentine belt on an 87,that was 88 and later.
Just take it off and remove the bracket if you can since emissions isnt an issue.
Old Apr 13, 2008 | 06:02 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Just so you know, emissions is an issue in all 50 states of the union if its a street car. Federal law says you cannot remove any emissions devices. But if you dont have emissions testing in your area, well there isnt much to stop you other than your conscience and concern for the air quality. Just keep in mind that your wonderful senator Clinton wants to have emissions testing for all cars, so dont throw your stuff away. You will have emissions testing eventually.
Old Apr 15, 2008 | 10:50 PM
Gord's Green Z28's Avatar
I'll second the comment about not throwing it away. Even if you never use it, the next owner might want to.
Taking the AIR tubes off will cause the car to run slightly leaner unless you've told the computer that the AIR should be disabled. Most people don't have an issue with the leaner setting.
HectorM52
Jul 30, 2017 11:46 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
