C5 rotors push the wheels out?
Old Apr 5, 2008 | 07:46 PM
wildweasel's Avatar
ALMOST done my C5 brake conversion (waiting for UPS to deliver ONE stinkin' bolt). When I was test fitting my rotors I noticed that the reveal on the hub was slightly less (3/16ths or so) than with the old LT1 rotors. Anyone else ever noticed that?
Old Apr 6, 2008 | 08:31 AM
maybe2fast's Avatar
are you saying the hub part of the C5 rotor is thicker? therefore making the wheels backspacing different and pushing the wheels out wider?
that would be cool! I have the C5 and ZO6 17s all the way around
Old Apr 6, 2008 | 11:24 AM
wildweasel's Avatar
Correct. I've still got the stock rotors on the back, so maybe I should look into some wheel spacers to make them match.
Old Apr 8, 2008 | 04:08 PM
maybe2fast's Avatar
bump for answers!
Old Apr 15, 2008 | 07:36 AM
mzgp5x's Avatar
I just did a Kore3 C5 97_4th gen front brake up_grade. The C5 rotors have the same cross section thickness @ the hub mount as the stock rotors. Therefore, I do not see how the zr1 wheels (17"x9.5") could be offset more than a stock set-up.
If one were to install the caliper bracket on the "outside" of the suspension link, and the hub, then, you would have a positive offset on the wheel mount. Could be done???... I don't know. The drawing/ schematic I received from Kore3 shows the bracket assembled in the "inside" of the suspension link. (97ss - 383 - D1)
B.
carguy0119
Apr 11, 2016 11:11 PM
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
jj_burchiel
Mar 21, 2015 12:51 AM
