Slp LM1 noob question
Old Apr 4, 2008 | 08:40 PM
Red93Camaro's Avatar
I want to get SLP loudmouths for my 93 Z28...But I did alot of reading and I have to get another part for the exhaust so It can be installed?
http://www.lmperformance.com/5598/2.html ( theres the exhaust )
http://www.lmperformance.com/1576/2.html ( and heres the installation kit for 93-95 LT1s?)
I have to get both of these to have the exhaust put on?
Then I noticed that there isnt a muffler, So I have to keep my stock muffler to have the Duel output?
Old Apr 5, 2008 | 01:50 AM
Green96Z's Avatar
There is no muffler with the LM1 setup, That bulged pipe is the resonator, which gives the LM its loud, raspy sound. It's just a straight through shot.
You need the installation kit that you linked, because the 93-95 catback ends further towards the front of the car compared to 96+ cars. Plus it changes your hangers to the 98+ style, which you will need for the LM1.
Old Apr 5, 2008 | 02:44 AM
ok, so theres no mufflers at all? that resonator pipe is at the end where the Duel output is? Near the backend of the car?
Old Apr 5, 2008 | 08:35 AM
2000GTP's Avatar
The y-pipes on the 93-95 cars were a single cat and the 96-97 a dual cat setup which changed their overall dimension. The 93-95 cars need an s-shaped piece of piping to connect the i-pipe portion of the catback to the y-pipe. Not a big deal.
Old Apr 5, 2008 | 08:55 AM
dangalla's Avatar
yes, no mufflers
IMO very loud and annoying
Old Apr 5, 2008 | 11:27 AM
Thanks, I hope putting this exhaust on will be easy...It'll be the first exhaust I've ever done. Will I have to weld and stuff? and cut the pipes to fit?
Old Apr 5, 2008 | 11:52 AM
2000GTP's Avatar
When making the catback to y-pipe connection, it will most likely need to be welded.
Old Apr 5, 2008 | 11:53 AM
dangalla's Avatar
i used a stainless steel band clamp, in case it needs to be removed
Old Apr 5, 2008 | 11:56 AM
2000GTP's Avatar
I was guessing the loudmouth will be 3" piping, the stock y-pipe is smaller, thats where I figured welding would come into play. Although I may be wrong, I could have sworn they made band clamps that could attach different sized piping?
Old Apr 5, 2008 | 11:59 PM
Green96Z's Avatar
The LM is all 3" piping, except for a short adapter that goes from the stock i-pipe size to the 3" LM size. All bolt on, no welding required (although you might want to to minimize leaks).
Old Apr 6, 2008 | 01:59 PM
Thanks guys! I hope this project will be easy! I'll post a pic story when I get the exhaust and the installation kit.
Old Apr 6, 2008 | 05:29 PM
Can I just take the Stock muffler off and replace it with the SLP LM1 shotgun resonator?
Instead of getting the whole catback?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
