how 2 run carb w/tbi harness
Old Apr 2, 2008 | 12:35 AM
madmerlin71's Avatar
running a 79 vette 355 w/holley carb,in a 93 s-10 4wd the only thing left is to hook up hei distributor,and terminate tbi wiring?any help would be greatly appreciated.................................madmer lin71@yahoo.com
Old Apr 2, 2008 | 09:41 AM
Rice Killer87's Avatar
What kinda dist. was in there? If it had an external coil you can use the pink wire off the coil for a switched 12V for the HEI dist and the white wire is the tach wire.
You could also use that pink wire spliced in for an electric choke if your running one.
Old Apr 2, 2008 | 04:32 PM
was an external dist.on the 4.3 tbi. can i just pull the fuses for the computer and throttle body? is the computer only controling the engine or does it control shift points too? any info is greatly appreciated thanks...........................madmerlin71@yahoo .com
Old Apr 2, 2008 | 04:38 PM
Old Apr 30, 2008 | 03:23 PM
Sorry man,but the computer only controls sensors,fuel pump and injectors.
Did you get it running yet?
mr28
Apr 20, 2016 05:44 PM
willismoons
Feb 14, 2015 08:42 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jan 5, 2015 07:14 PM
mr28
Nov 23, 2014 11:11 AM
