leaks with new Exhaust
Old Mar 18, 2008 | 02:37 AM
blkgagt94's Avatar
i gota leak around where i put a new cat at where it meets the y pipe it leaks along the top an some on the bottom an a lil in the back. what can i use to seal this up?
Old Mar 18, 2008 | 03:29 AM
mrmint69's Avatar
I used aluminum foil and band clamps. I folded it enough times that it was thick enough to hold up.
Old Mar 19, 2008 | 03:43 AM
Kaj's Avatar
Kaj
you could have it welded....
Old Mar 19, 2008 | 11:06 PM
blkgagt94's Avatar
ya i can have it welded but if i need to get it off i cant unless i cut all the welds an dnt really wanna do that
Old Mar 19, 2008 | 11:21 PM
Kaj's Avatar
Kaj
What kind of system are we talking about here?
Old Mar 23, 2008 | 04:48 AM
IdahoLT1's Avatar
i have an off road pipe that i swap out with the cat converter when emissions are due. The pipe and cat have flanges and bolt holes so i can swap it out fairly quickly. If you have this type of connection, you can buy gaskets for it or you can use a RTV high temp silicone sealant.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
