Will 94 single cat headers work on a dual cat car?
Old Mar 17, 2008 | 09:10 PM
TeamingTealZ28's Avatar
My friend just GAVE me MAC Mid-Lenght headers and ORY-pipe the other day. I wanna install them tomorrow.
THING IS.
he took them off his 94 single cat car...I have a 96 dual cat car.
Im taking the cats off completely will the headers and ypipe bolt up fine...cuase then im taking it to my exhaust guy and hes gunna connect the extension pipe to the "cat-back"
It should bolt up fine right?
Old Mar 17, 2008 | 09:59 PM
reimer96z's Avatar
yes
Old Mar 17, 2008 | 10:09 PM
They will bolt up and the y-pipe will bolt on fine too...the rest I will have to get fabbed up correct?
Old Mar 18, 2008 | 03:57 AM
Green96Z's Avatar
If they are race headers then yes they will fit. If they have AIR/EGR on them, then you will have to figure out a way to connect the AIR fittings, because 96 cars are different from previous years.
Old Mar 18, 2008 | 06:08 AM
2000GTP's Avatar
Headers and y-pipe will be fine. You will have to resort to 02 sims or tuning to take care of the rear 02 sensor codes and if you have the race style without the AIR or EGR fittings, you will have to have those tuned out as well. As for the catback, an exhaust shop should get that welded up to the y-pipe without a problem.
Old Mar 18, 2008 | 10:32 AM
How much are O2 sims anyway? And how many do I need?
Old Mar 18, 2008 | 12:44 PM
2000GTP's Avatar
They will run around a hundred a pair, they are getting harder to find as the EPA cracked down on them. If you are interested, PM me and I will give you a couple links.
Old Mar 19, 2008 | 06:06 PM
Cant I just get hte AIR fittings from a 94 car and thread it into the headers. Arent they the same.
liamcg97
Nov 25, 2019 05:55 PM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
