Old 03-16-2008, 12:36 PM   #1
2001Firehawk
NO MT with AFM ?? No V8 Camaros with MT ??
Just wondering if the Camaro will have a MT with AFM.
Quote:
Peper pointed out that both engines will offer cylinder-deactivation technology to shut off either three or four cylinders when they aren’t needed, to conserve gas.
[from another forum]
The G8 GT is NOT going to have a MT.
Why?
AFM requires communication with the transmission to work... when you shift your own gears, the AFM system can't respond fast enough and would get screwed up. This has been mentioned before in some of the interviews... The GT won't ever have a MT.
The LS3 does NOT have AFM and therefore works well with a MT.
2001Firehawk is offline   Reply With Quote
Old 03-16-2008, 01:23 PM   #2
JasonD
JasonD's Avatar
This should be interesting, good question.
JasonD is offline   Reply With Quote
Old 03-16-2008, 02:05 PM   #3
Dragoneye
I want to call BS. AFM has nothing to do with the Tranny. And the G8 is getting a MT last time I heard...it's just coming later.
All AFM does, is when the load is light enough (like stead highway cruising) the ECM shuts down the valvetrain (via special lifters), and spark of 4 cyllinders in V8's. When it they need to be reactivated, due to load, the engine just turns them back on. It's imperceptible. I'm certain the engine controller will be outfitted with paramaters for when the clutch is disengaged (i.e. NO load on engine, etc).
The LS3 does not have AFM because 'vette owners really didn't want it. Or weren't concerned with it. Or so I hear.
That's not true - the quote. AFM works fine with a MT.
__________________
Quote:
Originally Posted by CR97WS6 View Post
If you want to buy something else then do it, but you'll be jealous when that 5th gen passes your @ss and all you can do is drool!
"Keep the Faith."
Dragoneye is offline   Reply With Quote
Old 03-16-2008, 04:49 PM   #4
2001Firehawk
What GM cars now have MT & AFM ??
Old 03-16-2008, 04:58 PM   #5
Dragoneye
Quote:
ooh, damn. Hey - I wasn't saying that YOU were full of bs. I just re-read my post...and that's what it sounds like. I hope you didn't take it that way.
Anyways, MT w/ AFM....okay. So you caught me with my pants down. There are none.
But has it not been confirmed numerous time already that the G8 will be available with a manual tranny later this year?
Has it not been 99% confirmed that Camaro will have choice of V8/V6, manual or Auto-tranny. And the V8 will have AFM?
All I'm saying - is that I've read over how AFM works, check this link out: http://media.gm.com/us/powertrain/en...Car/08_L76.doc
It's GM's writeup of the L76 in the G8. It goes into great detail how AFM works (just short of measurements and part numbers )...and there's nothing about the transmission.
So there's no reason to worry that the Camaro V8 won't be available with a manual.
__________________
"Keep the Faith."
Old 03-16-2008, 07:03 PM   #6
Meatyshells
they have satellites that can see flies from space, im pretty sure GM can make a MT with AFM
Meatyshells is offline   Reply With Quote
Old 03-16-2008, 09:16 PM   #7
NVMY68SS
NVMY68SS's Avatar
Send a message via AIM to NVMY68SS Send a message via MSN to NVMY68SS Send a message via Yahoo to NVMY68SS
Has anyone seen what the 2009 G8 GXP is going to have though?
Quoted from Leftlanenews.com :
Power comes from a 6.2-liter LS3 small-block V8 engine delivering 402 horsepower and 402 pound-feet of torque. This engine is the newest member of GM's small-block V-8 family. It features a revised, larger-bore cylinder block, high-flow, L92-style cylinder heads; larger-diameter pistons; unique camshaft and camshaft timing; revised valvetrain with offset intake rocker arms; high-flow intake manifold; and high-flow fuel injectors.
The LS3 engine has an aluminum cylinder block with cast-in-place iron cylinder liners. Larger bores help create a 376-cubic-inch displacement. The block casting also features revisions and machining in the bulkheads to enhance its strength and improve bay-to-bay breathing. New pistons were designed for high-rpm performance.
And if you read the whole article, you'll see that it will also be coming with a 6 speed Tremec in 2009. Things are only looking better for the Camaro IMO.
__________________
3800 3-18-09 VIN Assigned, Car produced VIN #2G1FT1EW2A9100296
NVMY68SS is offline   Reply With Quote
Old 03-16-2008, 10:02 PM   #8
POWERFREAK
Quote:
YES, I agree. I can't imagine they'd release the GXP w/ an LS3 and not put one in the Camaro as well.
__________________
perma-grin 2SS/RS/M6/IBM
POWERFREAK is offline   Reply With Quote
Old 03-16-2008, 10:45 PM   #9
ImportedRoomate
ImportedRoomate's Avatar
Send a message via AIM to ImportedRoomate Send a message via MSN to ImportedRoomate
Another example of cylinder deactivation disagreeing with a MT is in the new Accord where the MT V6 lacks that feature.
__________________
BahamaTodd
2004 GMC Canyon Z71
ImportedRoomate is online now   Reply With Quote
Old 03-17-2008, 01:25 PM   #10
jg95z28
Premium Member
jg95z28's Avatar
Send a message via AIM to jg95z28
I'm wonder how many would hold off for a supercharged Z/28 if they can only get the SS with a A6.
__________________
My Current Chevys:
1967 Camaro Coupe - 350HO/TKO-500 (Old Blue)
1967 Camaro RS - 327/PG (Goldie)
1995 Camaro Z28 - LT1/A4 (Norma Jean)
2002 Tahoe LS 2WD - LR4/A4 (The Big Red Truck)
jg95z28 is offline   Reply With Quote
Old 03-17-2008, 06:38 PM   #11
ImportedRoomate
Or who is gonna be really pissed that they cant afford the supercharged Z/28 with the manual they want?
__________________
BahamaTodd
2004 GMC Canyon Z71
Old 03-17-2008, 08:23 PM   #12
fastball
Well, since it has already been confirmed by Bob Lutz himself that the Camaro will be available with 6 speed manual and automatics (go through the archives and search Camaro on GM blogs) for BOTH the V6 AND V8, I think this thread is rather moot.
IF they were to make an AFM model, I would assume GM would take the route Honda does with the Accord V6 in the coupe. All automatic transmission models are used in conjunction with the AFM equipped version of the J35 Honda V6 engine, and all 6 speed manuals are used on non-AFM J35s.
The computing done to determine when the engine should engage AFM requires calculations on speed, gearing, and RPM. Since manual transmissions are still rather rudamentary machines (I've yet to see a computerized stickshift), I don't think AFM can work right with a stick shift.
__________________
2010 Camaro Z28. 6 speed manual. Silver. Black Interior w/orange stitching. It will be mine...... Oh yes, it will be mine!
fastball is offline   Reply With Quote
Old 03-17-2008, 10:56 PM   #13
TrickStang37
the camaro may (probably wil) get an LS3, but the G8 is already at $30,000 with the L76. how much will they charge for the GXP?
I can see GM following along the same lines with the camaro.
TrickStang37 is offline   Reply With Quote
Old 03-18-2008, 12:49 PM   #14
Geoff Chadwick
Geoff Chadwick's Avatar
Send a message via AIM to Geoff Chadwick
FWIW I've heard from guys at Delphi that the AFM *can* work without the requirement of the automatic transmission - but that the gains in mpg are worthless and it switches in and out of AFM so much its a waste.
The automatics (espicially now with the fly-by-wire engine throttles) have enough control capability where they can more effectively calculate the ideal load/rpm/etc for the best fuel economy for an expected level of performance and a requested speed.
Manuals dont let the ecu control much of anything - much less how to optimize the reduced power output of the engine while AFM is active.
__________________
Z284ever "Why would you say that I dislike Zeta? Does it owe me money? Did it insult my wife? Did it pee on my lawn?"
GUTTERbOY "No, the God of Abraham watches over the line and will smite any worker who attempts to bypass the toaster."
Geoff Chadwick is offline   Reply With Quote
Old 03-18-2008, 01:10 PM   #15
supr_bikr_99
Send a message via AIM to supr_bikr_99
The G8 GXP will have a manual trans option. I think someone actually posted a screen shot of the GM Dealer World page a while back, but I can't seem to find it. As far as AFM with the MT, I have no idea. I hope so, but it's not a deal killer for me. I'd like to see E85 compatibility along with AFM, but if I get one or the other or neither I'll be perfectly fine
supr_bikr_99 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
