Old 03-11-2008, 08:16 AM   #1
GMRULZ
Scott S. are you guys addressing the IRS wheelhop issue?
I realize you can`t speak in specifics, but are you guys taking seriously the issue of wheelhop from IRS cars, and looking for ways to eliminate this from the Camaro, or is it not a high priority? The reason I ask is I have a z51 suspended 06 C6 mn6 and it wheelhopped its butt off literally till I replaced the shocks w/ bilstien sports. Its much better now, I still get it a little, but liveable. however I have heard this is a MAJOR issue on GTO`s and as I`ve said a lot of the M6 vette guys complain about it as well. I plan on drag racing the Camaro and I don`t want to have to spend 1-2k like the GTO guys do to eliminate the wheelhop.
__________________
1996 Ram air T\A
Lots a mods.......
GMRULZ is offline   Reply With Quote
Old 03-11-2008, 08:34 AM   #2
skorpion317
Don't forget the CTS-V.
__________________
1998 Camaro 3.8L M5 - Some bolt-ons, !Rear seats, '93-96 tail light conversion
15.269@90.84 MPH
2009 Malibu LS
2010 Camaro SS/RS M6
skorpion317 is offline   Reply With Quote
Old 03-11-2008, 09:18 AM   #3
1fastdog
Premium Member
1fastdog's Avatar
There may well be use of unequal diameter half-shafts. Such an approach can help minimize wheel hop.
We'll have to wait and see as time goes along.
Quote:
__________________
1969 Z/Z28 - 1970 1/2 Z28 - 1975 Vega Cosworth 1979 Z/28 1981 Citation X-11 -1982 Z/28 - 1984 Pontiac Fiero -1984 T1000 - 1986 Fiero 6 cyl -1986 Fiero GT-1988 Chevrolet S-10 Tahoe 1995 Z/28
2000 'vette FRC-2002 Z06- '03 Silverado-'08 Malibu
1fastdog is offline   Reply With Quote
Old 03-11-2008, 04:44 PM   #4
DvBoard
Didn't '07 C6's get a shock update that helped this?
__________________
/ OR . Traitors...
DvBoard is offline   Reply With Quote
Old 08-01-2008, 06:30 PM   #5
radz282003
Premium Member
radz282003's Avatar
Different sized shafts to quell oscillation.
__________________
-Chuck (your resident Z28 fanatic) Yes, I'm Hell-bent on a supercharged Z28! (please GM) 2002 Z28 NBM A4 3.23 Lid, C.B., stall, some suspension - 12.6 @ 109 1.6X 60' - all over the limiter
radz282003 is offline   Reply With Quote
Old 08-01-2008, 10:30 PM   #6
Big Als Z
Holden has done a lot to fix that, and Camaro team has gone further with the different half shafts. This was all done to stop wheel hop.
__________________
2009 Malibu LT 2.4: My NEW Ride! Yeah...no Camaro...I know I know...
1987 Camaro Z28
1972 Camaro RS: It's easy being green
Mod @ GMInsidenews.com
Big Als Z is online now   Reply With Quote
Old 11-26-2008, 11:32 PM   #7
DMS
DMS's Avatar
the G8 has wheel hop. A large amount of this is due to very soft bushings in the back. All the bushings in the back are the same with the Camaro and G8.
Pedders has rear cradle support bush inserts and rear differential mount bushings that will really firm up the looseness in the back end.
We also have every bushing, spring, damper, and 30 way adjustable coil overs, strut tower brace, and multi adjustable sway bars for the Camaro.
We are a preferred vendor for GM racing and helped them with the Koni Series Camaro that will be built by Riley Technologies Guess whose bushings will be on this great car!!
mike
dms
DMS is offline   Reply With Quote
Old 12-21-2008, 12:27 PM   #8
Leedogg 96TA
Send a message via AIM to Leedogg 96TA Send a message via Yahoo to Leedogg 96TA
How long before a 12bolt/9" conversion is available? That is the real question.LOL
__________________
--96 TA, 383ci, 11.8:1 comp, L.E. heads, CC 236/242 cam, MSD Pro Billet Opti, Spec 4 clutch, Strange 12 bolt, 3.90 gears, Ed Wright tune.
--408rwhp 398rwtq. 11.98 @ 115mph. 1.76 60' on 315 M/T DR's.
--Check my website for more details. http://www.fquick.com/leedogg
Leedogg 96TA is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
