Old 03-07-2008, 08:03 PM   #1
FUTURE TOP DOG OWNER
Thumbs up Rear tire size
Who's hoping the large/small tire combo
275's on the front and 315's on the rear (at least for the top model!!)
would be my wish!!
FUTURE TOP DOG OWNER is offline   Reply With Quote
Old 03-07-2008, 08:48 PM   #2
diarmadhi
I'm going to need to rotate tires.. I'd rather have wide meats at every corner of the same size.
diarmadhi is offline   Reply With Quote
Old 03-07-2008, 08:55 PM   #3
wildpaws
Quote:
Ditto, I want all the tread on the road I can get at every corner of the car, I'm looking for all around performace, not some "cool look" best suited for 1320!
Clyde
wildpaws is offline   Reply With Quote
Old 03-08-2008, 06:56 PM   #4
The "cool Look" And "1320" Comment Doesn't Make Sense!! If The Wider Rear Tire Set Up Was Only For The Quarter Mile Or Just
A "look" Why Would The Zo6 Wear A Set Of Wide Meats On The Rear!! If The Top Of The Line Camaro Is Going To Have A Speculated 500+ Horse (i'm Hoping) It's Going To Need The Most
Contact Patch To The Pavement As Possible!!
Old 03-08-2008, 07:06 PM   #5
Meatyshells
i dont car what they use, as long as it's not those stiff as hell run flates they use on the vetts
Meatyshells is offline   Reply With Quote
Old 03-27-2008, 05:08 PM   #6
mpilarZ281992
Again, car is to be "practical." Front/rear tire mismatch would not fit the practicality of the car. But yes, most supercars have the larger tire sizes for performance enhancement. But if you can afford a supercar (Z06 included) you just buy new tires more often.
mpilarZ281992 is offline   Reply With Quote
Old 04-03-2008, 12:14 AM   #7
96' Formula WS6
now I know that it was just a concept but I highly doubt they will have sepperate width tires. The new spy shots that just came out show a 245/45/20 pirrelli pzero tire.
__________________
~94 A4 Z28, Hooker Storties,ORY Hi Flo Cat 3' IMCO exhaust LPE CAI, Mez W.P. CC224/230, Scorpion 1.6's, 987's, 3200 vig stall, 373's
12.7 at 110 spinning
96' Formula WS6 is offline   Reply With Quote
Old 04-03-2008, 04:31 PM   #8
Z28x
Z28x's Avatar
Send a message via AIM to Z28x
I'd like the see the LS3 car get 275/40/20"s as at least an option.
Pontiac G8 comes with P245/40R19 or P245/45R18
__________________
2007 Chevy Equinox
previous cars:
2000 Chevy Silverado 4x4 W/T
2005 Chevy Colorado Z71 Crew Cab
2000 Camaro SS - 1999 Grand Prix GT - 1994 Camaro Z28
Z28x is offline   Reply With Quote
Old 04-03-2008, 05:48 PM   #9
DvBoard
The camaro SHOULD come with a constant size tire to help reduce costs on replacing them by allowing them to be rotated properly. If you want otherwise, go aftermarket.
__________________
/ OR . Traitors...
DvBoard is offline   Reply With Quote
Old 04-03-2008, 06:09 PM   #10
wildpaws
I really don't care what the Z06 has for a tire setup, wide tires (within reason) all around for maximum performance is what I want.
Clyde
Old 04-03-2008, 10:15 PM   #11
Maverick_997
Maverick_997's Avatar
Send a message via AIM to Maverick_997
i know that i am probably the only one to saw this but i would like smaller tires on them for drifting cuz i really would like to see more muscle cars out thier liek mine drifting instead of those ****in rice rockets that have so little power they never have to play with the throttle.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i54.photobucket.com/player.swf?file=http://vid54.photobucket.com/albums/g112/Maverick_997/Team%20STP/M2U00114.flv">
__________________
Jeremy
25th Anniversary Trans Am 6s.... Project 383 9/19/09
1998 Mustang GT 5S bolt ons-14.8 @ 93
2001 Trans am 6s - to the track when its dry
Maverick_997 is online now   Reply With Quote
Old 04-03-2008, 10:16 PM   #12
Maverick_997
wrong code
http://s54.photobucket.com/albums/g1...t=M2U00114.flv
__________________
Jeremy
Old 04-08-2008, 04:43 AM   #13
TrickStang37
315's still arent enough for 500+ hp.
and if they do come with the 245/45/20's, they are going to need to run 3.80+ gears in the rear end to barely MATCH the old 3.42 set up. And if it revs any higher, gearing will be that much worse.
TrickStang37 is offline   Reply With Quote
Old 07-21-2008, 03:34 PM   #14
AdioSS
Send a message via AIM to AdioSS
Somebody wins a prize!
Man those are TALL tires!
__________________
ChestonPhillips@yahoo.com
Quote:
Originally Posted by Bob Cosby View Post
Now we're speculating on the speculation....all the while, throwing more speculation into the mix. Is one speculation (or "most realistic guess") any better than the other speculation?
AdioSS is offline   Reply With Quote
Old 10-13-2008, 06:45 AM   #15
kookamunga
Send a message via ICQ to kookamunga
hope it will fit at least 315's up front like the 4th grns for autox duty
__________________
1999 SS Camaro with lotsa autocross stuff
kookamunga is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
