good dual set up
Old Mar 6, 2008 | 01:51 AM
97sscamaross's Avatar
good dual set up
I'm looking for a good true dual set up but I can't really find anything out there. some help and advice would be appreciated
Old Mar 7, 2008 | 03:42 AM
Kaj's Avatar
Kaj
There is only a couple systems offered:
Bassani
Texas speed (dumps before the axle, and will require modification because I believe it's for ls1 cars.
Anything else would have to be a custom fab. job.
Old Mar 7, 2008 | 01:43 PM
thanks, I looked up the bassani one and I can't find dictures of it
Old Mar 14, 2008 | 05:03 AM
Kaj's Avatar
Kaj
http://www.lmperformance.com/image.a...798rs5bx&m=175]
For the LS1, LT1 is nearly identical...
Old Mar 14, 2008 | 07:38 AM
2000GTP's Avatar
Alot of the TD setups you'll see on here are custom done. That has it benefits though, depending what you go with, it can be done cheaper then the Bassani kit and you also have more options available of how you want your setup ran and what components you want in it.
Old Mar 16, 2008 | 08:10 PM
Crows89RS's Avatar
Really, a lot of people I know just buy the Summit 2.5" or 3" x pipe kit, buy a couple of dynomax or magnaflow bullet mufflers and dump them. I've seen a couple of people do the duals like on lmperformance, but those are much costlier if that is an issue.
Old Mar 16, 2008 | 10:16 PM
Kaj's Avatar
Kaj
Originally Posted by 2000GTP
Alot of the TD setups you'll see on here are custom done. That has it benefits though, depending what you go with, it can be done cheaper than the Bassani kit and you also have more options available of how you want your setup ran and what components you want in it.
I agree, if I were to run true duals, I'd have the system custom made with my choice of mufflers, tips, w/ dual cutouts. The bassani system is just a way around the mess of finding someone to fab a decent over-axle TD system up for you, hence why it's so expensive, it's a very high quality piece in it's own regard, and sounds pretty good too. The price is just less than practical...
For example:
Bob is on a budget looking for an exhaust, he's got $1100. He could A: buy the bassani TD system or B: Buy pacesetter LT's, ORY, bullet muffler, and cutout: all but the gaskets, 02 sims and a mail-order tune. It's just not logical really to buy a $1000 exhaust system imo.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jan 23, 2015 01:13 PM
alphaauto
Jan 22, 2015 08:02 PM
