Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join nearly 80,000 enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
- Participate in over 40 different forums and search/browse from over 4 million posts.
- Communicate privately with other enthusiasts from around the world (PM).
- Post photos, respond to polls and access other special features
- Gain access to our free marketplace to buy, sell and trade cars, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support. |
02-16-2008, 11:49 PM
Convince me to put a cam in...
This summer I plan to replace both headgaskets and while I'm there I'm going to put headers on + 1.6RR's (been sitting in my room for a while). I've been having a small on/off oil seepage from the bottom of my timing cover as well. I was thinking since everything will be apart anyways would it be worth putting a cam in? Nothing major since its a DD I'm thinking Lt4 hotcam. Is this really something I would be able to do with out messing up? Is it really that much more work?
Also I had already bought LT4 springs/retainers/locks because I planned on putting the 1.6 RR's on w/ a stock cam. Now I understand the LT4 springs are borderline too weak for the LT4 hotcam, if I bought better springs would I still be able to re-use the LT4 retainers/locks or do I need stronger everything? I assume I'd need hardened pushrods too?
__________________
96' Formula M6 - Pacesetter LT's, ORY, Magnaflow CB, cutout, 1.6rr's, MADz28 Tune, CAI, K&N, LS1 driveshaft, Taylor 8mm wires, TR55's, TB bypass, !EGR, !AIR, LT4 springs, Felpro 1074 headgaskets, 6speedinc T56, LT4 PP, Hurst shifter.
02-16-2008, 11:51 PM
If you are doing all that you only have a few more steps for a cam. DO IT
__________________
1997 Trans Am Unstock
2000 YZF-R6 - Unstock
02-16-2008, 11:56 PM
Ya I read through shoebox's instructions again...it's the whole thing about "degreeing" the cam and all that that I hear people talk about which I dont know is necessary or not. I also hear you have to be very clean otherwise you can spin a bearing soon after...I have never touched a cam before in my life but done almost everything else including dropped my trans 7 times..yes 7..it was hell.
__________________
02-16-2008, 11:58 PM
I did my first cam swap on my car all by myself in 8 hours. It was on a gtp. Definitely worth it.
__________________
02-17-2008, 12:01 AM
Saying that you did it on a GTP doesnt really make me feel a whole lot better, considering everything on the LT1 is a PITA to work on. Have you done an LT1 swamp?
__________________
02-17-2008, 12:04 AM
Quote:
I don't know, a cam swap on a transverse(FWD) mounted engine isn't exactly a very easy task either. Do a search, I know there are some good cam writeups floating around. How fast you get it done is more so dependent on your skill level.
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
02-17-2008, 12:07 AM
No, I haven't. I was telling you that I did my first cam swap by myself in 8 hours with only email directions so being afraid of screwing it up should not be what's holding you back. But, if you think it's going to be that big of a pain, then don't do it. I personally am opting for nitrous on the LT1 instead of a cam... for now at least. I had nitrous on the GTP then went with the cam afterwards.
__________________
02-17-2008, 12:09 AM
Quote:
Tell me about it. I had to basically undo the whole undercarriage. For a dude who's major mods up until then was rockers, I can tell you it was quite scary. Looking back, I could bust it out in even less time. Probably 4-5 hours easy.
__________________
02-17-2008, 12:11 AM
Quote:
Yeah, I'd much rather do a cam swap on my LT1 then on my GTP. But ideally, I wish I could afford to pay some other poor smuck to do it for me.
__________________
1997 Camaro Z-28
02-17-2008, 12:12 AM
Do you hear that OP?!
__________________
02-17-2008, 12:16 AM
haha ok I forgot about the transverse v6 my bad. I don't care about it taking a while, I'll be taking 2 weeks to get everything done anyways I don't want to rush and **** something up like usuall. It just seems like there are a lot of horror storys out there about cam swamps thats all.
Would you put a cam in given what I will be taking apart?
__________________
02-17-2008, 12:18 AM
If you are doing all that you only have a few more steps for a cam. DO IT.
Do it.
__________________
Lets put it this way, I plan on changing my opti soon. Since I am changing my opti, I plan on doing the water pump. Since I am doing the water pump, I might as well do the heads and cam as well.
__________________
1997 Camaro Z-28
Here, this should be more that enough convincing. lt4 hotcam, thru pacesetter longtubes, ORY, and magnaflow.
http://videos.streetfire.net/video/1...e2012adcac.htm
__________________
1997 30th Anniversary z28 383 stroker a4->m6/3.23
-8.285 @ 85.844 mph, 1.883 60' still spinning, 330rwhp/390rwtq with a 16:1 A/F
1992 Toyota mr2 m5
-CAI, full exhaust
02-17-2008, 12:19 AM
Yeah, I had to pull the cam out through the wheel well!
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
