Old 02-14-2008, 08:22 AM   #1
detltu
Send a message via AIM to detltu
Questions about Direct Injection
So what is the big holdup with DI and why is it not a given in pretty much every new engine GM comes out with.
Is it a cost issue? Controls? What is different about putting DI in a 4 cyl versus an 8. Why has it taken so long anyways.
Anybody got any ideas?
__________________
1991 black Camaro z28-to hold me over till 2009
1999 Black Camaro SS Stolen
1989 red Camaro RS convertible- Sold
201? Camaro - wait for it... GM card:1000 cash:10,000
detltu is offline   Reply With Quote
Old 02-16-2008, 06:54 PM   #2
Grape Ape
To convert an existing motor from port injection to direct injection you need to:
  • Redesign the head(s) to add another hole for the injector and raise compression.
  • Redesign the pistons to deal with having fuel sprayed on them.
  • Replace the injectors with more expensive ones that can handle the pressure and temperature.
  • Add a (really) high pressure fuel pump, these have been failing on the LNF & BMWs 335
  • Replace the O2 sensors with more expensive wideband units.
  • Rewrite the software to run the injection and probably upgrade the ECM.
  • Since you are redesigning the pistons you may as well revise them and the oiling system to add squirters to cool the pistons and allow you to raise the compression some more.
So I’d say that GM is converting as fast as it can, but that is a lot of work. It would be a lot easier to adjust the bore and/or stroke to create new engine that without much more than a new crank, rods, pistons and maybe a little tweak to the software.
Grape Ape is offline   Reply With Quote
Old 04-02-2009, 10:56 AM   #3
My Red 93Z-28
Premium Member
My Red 93Z-28's Avatar
Send a message via AIM to My Red 93Z-28
The Gen V LS engines will have DI, but last I knew those were on hold.
__________________
'93 Z28 - LT4 + more, m29, TT2s, BMR, SPEC, QA1, etc,
Quote:
Originally Posted by Johnny Ray View Post
Don't ask me if you can ride my motorcycle and I won't ask if I can ride your wife.
My Red 93Z-28 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
