1996 3.8L Miss
Old Feb 5, 2008 | 07:49 AM
SuperSpike86's Avatar
Exclamation 1996 3.8L Miss
Hi crew,
My 96 camaro with 119,000 miles has begun 2 miss at random times during a drive. I replaced plugs and wires...twice. Any suggestions?
Old Feb 5, 2008 | 09:41 AM
SupplySgt.'s Avatar
I'm going through the same thing myself. Same year Camaro, a few more miles (132k. started missing at 125k though) I've done alot of things with mine and I'm not quite sure what else. All I can say is check everything you can think of and a few things you don't think of. basically check everything. I'm about to give up and just drop a low mileage engine in there for the time being and since it won't be my DD for much longer (maybe 7 or 8 months tops) it should last longer. But check everything and listen to what some of the other guys on here say. They definitely know what they're talking about.
Old Feb 5, 2008 | 05:43 PM
2000GTP's Avatar
Are you getting an SES light? Do you have it narrowed down to specific cylinders?
Old Feb 7, 2008 | 07:19 AM
I do have an Ses light but it's from an air mod that has been on since 90k. It's not throwing any codes, and as far as cylinder goes, it feels like the whole engine is about 2 die. It has a nasty violent shake when it misses.
Old Feb 7, 2008 | 07:25 AM
2000GTP's Avatar
What kind of air mod was done to it? If the car is misfiring bad enough, I'm sure if you put a scanner on it you would be able to record the activities.
Old Feb 7, 2008 | 07:46 AM
It was a "performance chip" I bought of e-bay. It's just a little wire that plugs into a connector end that is supposed 2 be on the fan shroud. Probably doesn't help and my harm. What do you guys think?
Old Feb 7, 2008 | 07:55 AM
2000GTP's Avatar
That mod has been discussed in the past, it is more of a gimmick then anything. Do you know exactly what SES light you have, that shouldn't be the problem.
Old Feb 24, 2008 | 09:06 PM
byrons1502's Avatar
did it get fixed
Old Feb 28, 2008 | 07:48 AM
The problem is still there, I took the "air chip" out, which I can't feel any difference, and I had a mechanic run a diagnostic test on it. It kick of an O2 sensor, and a Crank Position Sensor. I have since reset the SES light to see which one trips it first. I have never heard of Crank Position Sensor, so would that cause it to miss?
Old Feb 28, 2008 | 09:37 AM
2000GTP's Avatar
Do you know specifically what the 02 sensor code was? Depending on the code, it can give you some valuble information in regards to how the engine is running and if there is a specic problem on a certain bank or what not. Long story short, if there is an engine issue elsewhere, that can be leading to your misfiring problem. If you could give us the specific code, we could help you out a little more.
Old Feb 28, 2008 | 04:21 PM
It was the left bank O2 sensor that is all the mechanic told me. I have cleaned all the connections on all sensors with the cleaner stuff available at Autozone, and reconnected them. Maybe this will work, because my waterpump went out a few weeks ago and slung antifreeze everywhere.
Old Feb 28, 2008 | 05:03 PM
2000GTP's Avatar
If you get the SES light again, get the exact code and post it up. Good luck and keep us posted.
Old Mar 6, 2008 | 07:30 AM
Well I played it the easy way out with the O2 sensor, and replaced all four of them. I figured at 120,000 they were shot anyway. My mechanic is currently replacing the Crank Position Sensor, and he said that on the 3.8's this seems to be the only problem they have. I'll keep you guys updated if this fixes the problem or not.
Old Mar 6, 2008 | 01:40 PM
2000GTP's Avatar
With that amount of mileage, it was probably a safe bet to replace all of them. I agree with him, I have seen the CKP sensor being problematic on the 3.8s.
Old Mar 6, 2008 | 03:02 PM
valter's Avatar
Ignition coils are VERY common thing that causes miss on these cars. Sticking EGR valve can make it too (if your miss is worse on cold engine).
