tranny lines
Old Feb 2, 2008 | 01:27 AM
2nd 2 noss's Avatar
tranny lines
I have a 96 z28 a4.. my tranny line is leaking very bad. here is the deal I need to see if it is loose or is it bad.. do i have to drop tranny to tighten top line? is there another way? where can i get a new one?
Old Feb 2, 2008 | 04:39 AM
Ricardo's Avatar
You dont have to drop the tranny.
It is a bit tight in there, but you can work your way up there and slip your hand in with a stubby box end wrench or a flare nut wrench.
It helps a bit to drop the tailshaft.
If the nut is just loose it should be an easy fix.
You need to get your car up on a lift or at least generous space underneath to get this done.
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
737drivr
Feb 20, 2015 11:54 AM
