Ok ordered my converter and Flexplate.....
Old Jan 27, 2008 | 03:07 PM
Sunsetmaro's Avatar
Cool Ok ordered my converter and Flexplate.....
I just finished ordering my TCI flexplate and YANK SS3600 stall and ARP stall bolts. I will have to drain the tranny fluid during this process. What new tranny fluid should I consider getting? Ive recently had the tranny built-up and im not sure what I should put in there. Royal purple? Will their be any more small parts I need during the process of instillation that I was run into, like spacers or anything? I don;t want to have everything ripped out and being stuck because somethings missing.
Old Jan 27, 2008 | 03:42 PM
Kraest's Avatar
Retired
I would definetly put a synthetic fluid in there like synthetic Royal Purple ATF, synthetic Amsoil ATF, Synthetic Red Line ATF, etc along with a transmission cooler like the B&M Supercooler that has a 24,000 GVWR.
Nothing kills an automatic transmission like heat does, so it's imperative that you keep it as cool as you possibly can.
Old Jan 27, 2008 | 05:48 PM
Sunsetmaro's Avatar
Will I need anything else during this job?
I will look for the synthetic and order a B&M supercooler. What other parts will I need? I want this swap to go as smoothly as possible, tool wise im good. What are the ft lbs specs for the flexplate and torque converter? I haven't looked it up yet but ill just ask while im posting this.
Old Jan 28, 2008 | 08:04 AM
AL SS590 M6's Avatar
First off this belongs in the drivetrain forum. And I will put it there in a minute.
On the trans fluid, I drag race my car regularly and firmly believe that any name brand dino trans fluid (changed once a year) works just fine. I started in the low 13s and went clear down to 11.teens over a span of 8 years with the stock trans/Trango kit/big stall/big cooler. I just replaced the trans in the middle of last season because it was slipping just a little at the top of the track. Would it have lasted longer by using synth trans fluid? I doubt it.
There are no parts that you need to have to install the converter and flexplate.
Old Jan 28, 2008 | 11:12 PM
'94 Bad A Z28's Avatar
YANK says to NEVER use a synthetic trans fluid with their converters.
Old Jan 29, 2008 | 06:34 AM
cause4panic's Avatar
any where that there is a clutch, lsd, converter, auto tranny, etc etc dino is the way to go.
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
timmy39120
May 2, 2015 05:12 PM
WildRidez
Feb 23, 2015 07:24 PM
ChrisFrez
Feb 15, 2015 07:49 AM
joe777107
Dec 1, 2014 09:32 AM
