abs wheel sensor
Old Dec 13, 2007 | 02:23 PM
jcraftz28's Avatar
abs wheel sensor
how do i clean a wheel sensor? my abs inop light came on and when i had it checked it was the wheel sensor and i was told that i can clean them and it may start working again.
Old Dec 14, 2007 | 07:40 PM
greenmachinedriver's Avatar
take the sensor out and wipe it off. try using compressed air to blow any debris form the reluctor wheel area. usually dirt will not interfere with abs sensor operation. unless its exessive like if your brakes went meatal to metal and the sensor was coverd in meatal shavings. more than likely you will have to replace the sensor.
Old Dec 15, 2007 | 01:03 AM
RE AND CHERYL's Avatar
Only the rear sonsors can be removed. The front sensors are mounted in the front hub assemblies and are not able to be serviced.
Generally, cleaning won't accomplish a thing as they are magnetic. Your gonna have to replace it unless the plug is just loose or something.
Re'
Old Dec 15, 2007 | 11:01 PM
Re'
good point i forgot the front sensors were not removable. what sensor did it se a code for?
Old Mar 23, 2008 | 09:39 PM
1997FormulaBird's Avatar
I also have this problem sometimes.
it seems that the light comes on when it is very cold out and is fine when it is warmer.
the whole thing seems weird to me
Old Mar 25, 2008 | 04:53 PM
jcraftz28's Avatar
my prob was the headers on the pass side burned the wires in two. trace your wires from the wheels back.
Old Mar 25, 2008 | 08:16 PM
n2ceptor's Avatar
Did you check brake fluid level???? Also the neg ground on the passenger side fender well????
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
