Help!!!how to remove drivers seat...
Old Dec 8, 2002 | 03:29 PM
stik6shift98's Avatar
how do i get it out.....theres no bolts that i can get to...
Old Dec 8, 2002 | 04:17 PM
Kwiksilverz28's Avatar
Move the seat forward or back. Get the 2 bolts there (you have to pull the robber caps off the studs), then move the seat to the opposite position and get the other 2. If the seat is stuck, you have to get under it with a wrench. Not fun, but doable.
Let me know if this doesn't help.
Old Dec 8, 2002 | 04:25 PM
thats kinda hard to do with battery unplugged....
ill try it...
and do u know where to get mounting brackets for racing seats...r1 racing seat
or does anyone
thanks
Old Dec 8, 2002 | 04:27 PM
wilbs600's Avatar
First i got the front two nuts off then I put the seat all the way forward and got the rear nuts off. I know there is a plastic piece over it but just bend it a little or maybe you won't even have too. Before you pull the seat out make sure to disconnect the power seat wires from the seat so you don't break anything. Good luck.
Old Dec 8, 2002 | 04:36 PM
thank you
hopefully all will go well
i need the mounting brackets still
Jun 6, 2015 08:27 AM
ModdedNerd
Jan 29, 2015 07:23 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
squarehead
Nov 21, 2014 08:02 PM
