Rear end swap, drum brakes to disc brakes, any difference w/ brake line pressure?
Old Nov 29, 2007 | 11:34 AM
sick94's Avatar
I have a 94 camaro 3.4l w/ drum brakes. I also have a 97 firebird w/ the Y87 pakage which has disc brakes and lsd. I swaped the entire assembly from the firebird to the camaro, ebrake cables and everything. I had my brakes bleed b/c I didn't have anyone to help me, but now my brake pedal has very little pressure. My question is there anything difference between the the pressure needed to operate disc brakes and drum brakes? Is there a proportioning valve I need to change or anything?
Old Nov 30, 2007 | 10:43 PM
Jared 3870's Avatar
I put an LS1 rear into my 97 3.8 back in the day no questions asked, worked just fine.
Old Dec 4, 2007 | 12:48 AM
sick94's Avatar
^ but did you have drum brakes to begin w/? i just don't understand why the pedal is so low. there is no air in the system.
Old Dec 17, 2007 | 02:44 AM
sick94's Avatar
ttt?
Old Dec 17, 2007 | 06:19 AM
cause4panic's Avatar
5 dollars says theres air in the lines
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
