455 or 400 needed.
Old Nov 2, 2007 | 09:40 PM
henryz28's Avatar
455 or 400 needed.
What is the cheapest place to get a pontiac 400 or 455 for a 1973 firebird. thanks
Old Nov 3, 2007 | 07:33 AM
drptop70ss's Avatar
I have a nice pontiac 400 with some aftermarket improvements that is ready to run, NY zip 12538, pickup only no shipping.
Old Nov 3, 2007 | 12:36 PM
angel71rs's Avatar
Can also ask here:
http://transamcountry.com/forum/
Old Nov 3, 2007 | 02:58 PM
henryz28's Avatar
I am in CA.
Old Nov 4, 2007 | 07:15 PM
henryz28's Avatar
Ok guys I got a creat 400. It is the ram air v8 with 366 hp. I plan on just doing a cam and valve springs. What cam would be best for the ram air heads? I don't want to over cam it. Thanks
Old Nov 5, 2007 | 09:35 AM
jerminator96's Avatar
What do you mean by "best" and "over cam"?
If you want the most power possible out of those heads you will most likely end up with a cam that is fairly unruly on the street.
What are your goals for the motor/car?
Old Nov 5, 2007 | 03:04 PM
henryz28's Avatar
Ok what cam can I go with without absolutely having to run a larger stall.(Stock stall)
Old Nov 5, 2007 | 03:12 PM
Autos are out of my range of knowledge. I'm sure someone else can help you with that.
Old Nov 5, 2007 | 10:58 PM
angel71rs's Avatar
I run a 224* flat tappet cam in my sbc 400 with a stock converter and that's about the limit IMO.
Old Nov 6, 2007 | 12:34 AM
henryz28's Avatar
Ok thanks, what kinds of times do you think it will get? Because my uncle is trying to build it to beat me. But I don't think it will run a 12.1 with stock stall and the ram air 400 with a cam only.
Old Nov 6, 2007 | 09:28 AM
angel71rs's Avatar
I don't think so either. With stock stall, smog heads, 750 vacuum secondary Holley on a dual plane intake, 3.42s & Radial T/As, my best is a 13.7 @ 101. Track altitude = 4,100 ft, so figure ~ 13 flat at sea level. He'd need more stall, gears, cam, and a sticky tire to run low 12s.
Old Nov 8, 2007 | 10:31 AM
giwanabe's Avatar
Question
I too am considering building a 400 from a 1971 impala what can I do and why do many people refer to this engine as weak kneed? I want to obtain atleast 450 rwhp from a streetable application with 3.73 gears, long tube headers, and whatever bolt on aftrmakets parts I need. I need guidence. Also I here of people stroking the moter to a 406 but a 350 gets stoked to a 383 I dont understand why a 400-406 would make a good amount of power.
Old Nov 8, 2007 | 11:56 AM
Alright, let's start with the 400 sbc's bad rep. A lot of people used this block (and still do) for racing because of its large bore (4.125") and capacity for large stroke. It's not a particularly strong block when you start boring the cylinders and running a lot of boost or nitrous, or even just high RPM horsepower. It's also not as weak as some people make it out to be, you won't have a problem with your power goals. If i'm not mistaken the earlier 400 blocks (like yours) are stronger though.
Second, a 400 block does not get "stroked" to a 406, it gets "bored" .030" over its stock 4.125" bore. That is just a common practice to clean up the cylinder walls and perhaps unshroud the valves. A 350 is turned into a 383 swapping in the crank from a 400, which has a longer 3.75" stroke (hence the term "stroker motor"). If you want to do something similar to your 400 then give it a 4.0" stroke with the .030" overbore and you have a 434, without the .030" overbore it is the famous chevy 427.
Third, if you want to make good power out of your motor then don't look at the shortblock, look at the heads. Buy yourself a good set of heads and then build the shortblock into something that the airflow of your new heads can support. Get a good intake and cam to match your goals and voila! you have yourself a bad nasty, streetable, 450rwhp.
Just my humble opinion, I'm sure some of the other guys on here can help you further.
Old Nov 8, 2007 | 11:36 PM
giwanabe's Avatar
Thats some good info Jay thanks do you recommend a head and cam set? Also when you say build the short block are you talking about pistons cranks and rods or what? Its ok to laugh I am very new to all of this but I want to learn so I will stumble around in the dark if I have to. But I digress. Is there a kit or something to that effect already put together or do I have to peice the components together myself. One more question if the 426 hemi put out 500hp does that mean the 427 could also?
Old Nov 8, 2007 | 11:49 PM
henryz28's Avatar
Your 400 can make over 500hp with the right heads and cam.
