Need help with my LS1 in 1996 Z28!
Old Oct 28, 2007 | 08:06 PM
Mike96z's Avatar
Alright, got everything done and in the car except the fact I need a powersteering pulley and extend one of my o2's. The only problem is that for the dash wiring there are 3 connectors coming through the firewall like the LT1 and 2 are the same but one of the other connectors are different, not sure what they go to and how I need to wire them up. Getting pics tonight and also the same deal with under the hood wiring, 2 connectors connect to the harnesses but one is left alone, a grey one with nothing to go to, probably goes to the underhood fuses and will have to be wired into my dash to work on my fuse boxes. Will get pics as well. After everything was installed, hoped to atleast get it to start and turn over but did nothing, no radio, just lights and the noise when you got the door open. No fuel pump noise either. If anyone could provide me with help Id really appreciate it, and the people who have done it in an LT1 car. I could solve this by buying the LS1 dash and wiring but wanna see my options first and if its feasable. Engine is a 98 ss motor with wiring harness and PCM, 6 spd.
Thanks
Old Oct 29, 2007 | 12:56 AM
Mike96z's Avatar
dont know where these grounds should bolt too
the white connector, from the LS1 harness
the black connector in the LT1 dash harness
the 3rd body harness connector, have no idea where it goes
as it sits
Old Oct 29, 2007 | 01:43 PM
Rice Killer87's Avatar
Those grounds bolt to the back of the head. Should be a stud sticking out back there or just use a bolt.
Sorry,cant help on the connectors.
Old Oct 31, 2007 | 01:26 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
go to www.ls1tech.com to the hybrid section. They have all the wiring schematics for your problem in the FAQ sticky.
What did you do for the fuel issue? Run 97 vette rails or go with another fuel line and a FPR?
Old Oct 31, 2007 | 03:47 PM
Mike96z's Avatar
97 fuel rails with the walbro LT1 fuel pump.
Old Nov 1, 2007 | 07:41 PM
GhostZ28's Avatar
I always think that looks weird, the old style radiator support and LT1 intake elbow, on LS1 swaps.
Old Nov 2, 2007 | 12:02 AM
From what i've researched... theres not much other way to do it unless you do the LS1 front end swap.
Old Nov 2, 2007 | 09:18 AM
Mike96z's Avatar
theres a way but it calls for a flat, custom radiator support, and cut it so air can get sucked through the airdam, and then it will fit under the LT1 hood, otherwise conversion.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
siguy
Nov 27, 2014 10:07 AM
Carson96Z28
Aug 28, 2002 05:23 PM
