What is the best exhaust setup for the most power?
Old Oct 12, 2007 | 05:08 PM
CALL911's Avatar
Obviously this question could be answered differently depending on the individuals setup. But specifically for my 95 Z in my sig. I am running 614 RWHP (supercharged) right now. I currently have Hooker LTs, into a Hooker Y pipe, and then Borla Exhaust (middle plate). I have heard that dyno results with numerous cat back systems showed Borla as gaining the most on the same setup cars, but what about the rest? I am guessing Kooks might gain me a few more ponies, but what about the Y-pipe?
Any comments welcomed, but would prefer comments from people who have experience with what they are saying.
Old Oct 12, 2007 | 05:45 PM
streetbad's Avatar
What size is your mid-pipe (from the y-pipe to the muffler)?
Old Oct 12, 2007 | 06:01 PM
CALL911's Avatar
Its the standard size for a hooker Y-pipe into a Borla Catback. (3 inch)
Old Oct 12, 2007 | 11:37 PM
Bayer-Z28's Avatar
Ahhem..
http://web.camaross.com/forums/showt...of+of+the+best
Old Oct 13, 2007 | 03:58 AM
CALL911's Avatar
Originally Posted by Bayer-Z28
Uh..... Dude?...... Thats good and fine, but your post is refferring to a N/A LS1 car. It is kind of a different ball game for a supercharged LT1. I don't even know that Kooks makes a Y-pipe for the 95 LT1's.
Again, any comments welcomed, but comments from people who have some experience would be preffered.
Old Oct 13, 2007 | 09:10 AM
The SRZ's Avatar
Ben if you are worried about DB levels Kooks 1 7/8 stepped then int their y-pipe then using a 4" mufflex w/ magna muffler and not the spin tech for choke master. Best bet would be to ask the FI guys. I've got 7-8 mos left man I'm stateside bound. We put McGuire on our list too.
Old Oct 13, 2007 | 09:22 AM
CALL911's Avatar
Silas, not really worried about the DB levels, just wondering what the best setup for power is. I am sure Kooks are probably the best headers, and I am confident Borla is the best catback, but I am just wondering ideally what the best y-pipe is. It doesn't really matter as my setup is still pretty good, and I think it would be foolish to spend the kind of cash Kooks and a new Y-pipe would cost for the actual minimal gains it would net me, but I am curious none the less.
I will be outta McGuire no later than March, so if you get it, I'll miss ya, but who knows where I'll end up, and being a flyer, and going places, I'm sure we'll continue to meet up. Good luck man.
Old Oct 13, 2007 | 09:45 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I've got to buy an exhaust, and beyond Kooks headers I'm not sure what I'm going to do. I'm pretty sure their 1 3/4" will be fine for anything I ever decide to do to my car. I also think I'm probably going to go with the GMMG Catback. But I'm not sure what to do about the Y-Pipe. For all I plan to do to my car, the Kooks Y-Pipe would probably be fine, and it may be the only choice without having one made. According to Thunder racing, the Kooks Y-Pipe go from 3" Inlets to a 2-3/4" OEM style outlet. Is that the case for most Y-Pipes? Is it a restriction? I'm just curious because I thought most Cat-Backs were 3". Do people cut that portion of the Y-Pipe off?
I'm not trying to hi-jack, and maybe I should start my own thread. I'm just hoping to get some discussion going because I need to decide what I'm going to do pretty soon.
Old Oct 13, 2007 | 11:53 AM
CALL911's Avatar
You may have not intended to hi-jack my thread, but you are asking stuff totally different than my question, as it pertains to your car. Please go with your own suggestion and start your own thread. I am still trying to find info on my question with not much help yet.
Old Oct 13, 2007 | 04:21 PM
Bayer-Z28's Avatar
I'm just referring to the theory behind it all.. A good Y pipe like the Mufflex w/ a merge collector and a good set of scavenging LT's should work great. But then again, depending on your cam, you don't want the exh to suck too hard w/ the FI and valve overlap.
The Hooker areo-chamber is said to flow pretty well. You may want a little back pressure too.
Old Oct 14, 2007 | 01:41 AM
CALL911's Avatar
I used to have a Mufflex y-pipe w/ a merge collector before I swapped to the Hooker Y-pipe, and I actually gained a few more HP on the dyno by swapping out the Mufflex.
Old Oct 14, 2007 | 09:34 AM
Bayer-Z28's Avatar
^ good to know! THat merge Y is supposed to be good.
Old Oct 14, 2007 | 12:08 PM
Greed4Speed's Avatar
3" is a limitation on heads/cam NA cars. I'd go mufflex 3.5" or 4" or 3" true dual. You may try asking in the FI section also.
As for headers, I kind of like the QTP's.
Old Oct 14, 2007 | 03:40 PM
CALL911's Avatar
It must depend on the setup then as I just said I lost power (dyno proven) when I was running the Muffles 4 inch y-pipe vs. a Hooker 3 inch Y-pipe. It just didn't look right to me underneath as the 3 inch collecters from the LT.s went to a 4 inch, and then the reducer made it go back down to 3 inches. That, and the Mufflex didn't fit underneath nearly as neatly as the hooker did.
Now, you may have a point on the true duals, but thats a bit of work to change, and not what I would ever be willing to do.
Old Oct 14, 2007 | 03:56 PM
reamo04's Avatar
duals really are quite easy. Buy the summit kit, and pretty much everything lines right up. Do it with some bullets or flowmaster 1 chambers and you should gain quite a bit of power.
