how much is 2 much?
Old Oct 11, 2007 | 03:32 PM
greencamaro's Avatar
how much is 2 much?
I just hooked up nitrous and dont know how much 2 spray its a wet kit my lt1 has some miles on her but seems 2 run good i dont know how much horsepower it puts down but im running 12.21 in the 1/4 @121 mph with a 1.8 60ft its spinning bad but i think thats pretty decent for no tune and stock bottom end im thinking about a bigger tire 2 hook up and see if i cant hit 11s before i spray any suggestions would be appreciated im thinking a 100 shot do to high miles
Old Oct 11, 2007 | 04:12 PM
Ok4thGen's Avatar
Wow, i didnt understand much of what you said neither will anyone who reads it, it would help if we knew what motor your running what supporting mods you have, etc, let us know what were working with here so we can even begin to help you out, you know LSX LTX etc?
Old Oct 11, 2007 | 04:33 PM
yeah i posted this while i was setting up my account then my computer died but yeah im new 2 this and i thought i had it figured out
Old Oct 11, 2007 | 04:37 PM
Cool
im going 2 get the bottle filled right know its a little wet outside as soon as it dries it will be on im exited 2 see how it reacts hopefully I can make a good pass this weekend but im still up for suggestions on how much 2 spray
Old Oct 11, 2007 | 05:08 PM
waterbug1999's Avatar
You most be a manual guy... I hit 124mph on the 100 shot but run a 10.87 though. N/A with the N20 tune a 11.75 this last Friday.
My LS1 has 101, 000 miles on it at the momnet and prolly 12 or so bottles thru it.. I would stick with 100 shot and just watch the A/F closely.
I think with a 100 shot, if you spray out of the hole, you should be low 11's no problem, but is depends if you hook or not.
Old Oct 11, 2007 | 05:34 PM
Smile
yeah stock t56 with powergrip clutch your numbers were close 2 what i was thinking i hope i can hook but the stock rear end scares me
Old Oct 11, 2007 | 06:08 PM
I can pretty much say that if you spray out of the hole and dump your clutch, your rear is history!
I still have my 10 bolt but I am an A4, which are ALOT easier on the rear end.
Old Oct 11, 2007 | 09:04 PM
ive been leaving the tire pressure up so it dont hook 2 hard but im pretty sure after this weekend its overwith im giving it all she gots and then some all i need is a set up kit and my moser 9 inch will be ready so thats a plus
Old Oct 11, 2007 | 11:44 PM
If you can hook that bitch on the spray, hold on buddy and take a deep breath!
