lca relocation
Old Aug 28, 2007 | 10:02 PM
green96ta's Avatar
lca relocation
how much did the brackets help your et's...im hoping for at least a tenth, maybe two....
Old Aug 29, 2007 | 11:39 PM
green96ta's Avatar
anyone out there????????????????
well anyone out there???? any input at all would be appreciated
Old Aug 30, 2007 | 09:06 PM
green96ta's Avatar
ok
well i guess im the only one on this forum with relocation brackets...
Old Sep 1, 2007 | 12:43 AM
silverz28camaro's Avatar
try them out and let us know, if you have a problem spinning then they may help you a little.
when i put my lower control arms on, i did notice a great deal of the rear end being more solid and keeping the tires on the ground.
Old Sep 1, 2007 | 12:48 PM
Z-RATED94's Avatar
If you have drop springs, the relocation brackets will help. How much, who knows? What kind of 60s are you turning now? What tires are you running? With the right tires (DR's) you probably wouldn't even need the brackets, with your mods.
Old Sep 1, 2007 | 01:56 PM
green96ta's Avatar
well
i turn 2.069 on the 60 foot. however i have been getting a lot of wheel spin and hop, goin to beech bend tonight so i will find out...
Old Sep 2, 2007 | 01:51 PM
Z-RATED94's Avatar
Well, how did you do? Ever think of boxing your control arms? Is your TA adjustable? Maybe you could get and adj. panhard rod to center the car over the rearend. How about an air bag for the pass. side rear spring? With the right changes and some DR's you should at least cut some 1.80 60's if not better.
Old Sep 4, 2007 | 10:21 AM
sn8ke eatr's Avatar
i have lca relocation brackets on a rear i recently picked up. if you want ill let you know if it helped. you know the brackets will only help if your lcas werent at a good angle right? so if you have a stock size tire relocationg the lcas wont help and could possibly make it worse
Old Sep 5, 2007 | 08:05 AM
Z-RATED94's Avatar
Tire size has nothing to do with the angle of the LCAs. Unless your using different sizes front to back. Lowering springs or worn out springs, is a different story.
Old Sep 7, 2007 | 11:09 AM
Vicious95Z28's Avatar
Right, unless you put a taller tire in and then changed the length of the springs to fit them(longer). This would change the rear susp. geometry and move instant center.
Old Sep 7, 2007 | 11:13 AM
no, lca relocations drop the diff side of the control arm which would move the instant center further back under the car. Most susp. gurus will agree that at a factory stance the i/c is somewhere in front of the car. By lowering the lca on the diff side you move the i/c back under the car causing more lift on the body. This should never hurt traction only 10 bolt rears
Old Sep 7, 2007 | 01:48 PM
Norm Peterson's Avatar
Side View IC in the OE torque arm rear suspension is pretty much directly under the chassis side torque arm mount. If you've got a short link at the front of the TA as in some aftermarket TA's, it'll be in line with the axis of the little link (which may not always be vertical).
Tinkering with the LCA inclination in a TA suspension mostly moves the IC up or down. Not much at all forward or rearward. Moving the IC up accomplishes some of the same effects as moving it rearward does for a 4-link.
Norm
Old Sep 7, 2007 | 03:52 PM
Norm, can you elaborate a lil more on this?
Norm
Old Sep 8, 2007 | 07:42 AM
The SVIC for a TA suspension is the intersection of a line drawn perpendicular to the TA axis at its chassis attachment and a line drawn through the LCA axis. Figure 17.41 in the Millikens' "Race Car Vehicle Dynamics" book, if anybody has it or knows where JonA may have it posted. Since the TA is essentially horizontal, perpendicular to that puts the IC almost directly underneath.
Basically, the TA would rotate about its chassis end if it was pin-connected there (a la GNX/Kirban/single central ladder bar), but since it can 'plunge' in the fore/aft direction at the chassis it needs the LCAs to complete a stable linkage in side view.
Anti-squat is measured by the slope of a line drawn through the center of the contact patch and the SVIC. So for any given amount of anti-squat there can be an infinite number of possible SVIC locations, and the A/S can be increased by either moving the SVIC rearward without moving it upward (possible with a 4-link) or upward without moving it rearward (typical of TA). Note that anti-squat is only a rear suspension effect; other chassis effects may depend on the fore/aft location of the SVIC.
Norm
Old Sep 8, 2007 | 08:56 AM
So, moving the chassis end of the t/a upward (toward the floor board) increases anti squat?
