Hit a curb
Old Aug 19, 2007 | 08:03 PM
lsone's Avatar
Question Hit a curb
I hit a curb with my passenger front wheel and messed up alignment. The tie rod was bent so i replaced that and now the steering wheel is straight but I noticed that the wheel is still 1 inch closer to the center of the car then the drivers side wheel. The A-arm doesn't look bent could it be the spindle?
Old Aug 19, 2007 | 08:31 PM
wrd1972's Avatar
The spindles are known to get bent when taking a hit.
Old Aug 19, 2007 | 08:55 PM
lsone's Avatar
Would a bent spindle cause any other bent parts?
Old Aug 26, 2007 | 03:44 PM
MeanGreen97Z's Avatar
It could.... possible upper A-arm damage. I'd get under there and look.
Old Aug 26, 2007 | 08:04 PM
jclark311's Avatar
Sometimes its hard to see a bend in an A arm, the lower control arm moves in and out, about an inch on the K Member, by loosening those 2 big bolts, can you straighten this way? is the wheel on an angle? The fastest and easiest way to fix , is just throw on used A arms, and a spindle. If its a 93-97, you shoudnt have any trouble finding them cheap, or you could just do the LS1 brake upgrade, and buy a used lower control arm, most of the time you dont bend the top A arm, unless you really smacked that curb.
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
