Do i need an FMU with a tune?
Old Aug 4, 2007 | 01:04 AM
mrmint69's Avatar
My supercharger came with the FMU unit. I want a tune and was wondering if i would just remove it and the tune would work without it? I assume this but i haven't seen it written anywhere.
Old Aug 4, 2007 | 09:21 AM
Sparkz28ss's Avatar
you would need bigger injectors if yu want to ditch the FMU
Old Aug 4, 2007 | 09:39 AM
Boosted_Z28's Avatar
Agreed, larger injectors would typically be needed, but in my opinion, this this the much more prefered method anyway. Even with 6-8lbs. of boost, a good quality fuel system, larger injectors (usually around a 42lb. on a 350ci motor) and a quality dynotune makes the drivability of the car so much better not to mention some perforance gains as well.
Old Aug 4, 2007 | 12:54 PM
mrmint69's Avatar
My injectors are factory with 108K miles. What would i want for brand and size for my setup? 42lb sounds big but what do i know.
Old Aug 4, 2007 | 01:50 PM
JWS6's Avatar
I'm running 42lbs injectors and no FMU also.
Old Aug 4, 2007 | 02:03 PM
A "larger" injector won't cause any problems as the PCM will turn it on only for the length of time needed by lowering the duty cycle. 42lb. injectors are typically a good choice for your application and they will give you a little room to "grow" as well. I ran these in my 350 ci motor with 10lbs. of boost and the drivability was fantastic.
Try these guys:
http://www.racetronix.com/
Old Aug 4, 2007 | 05:14 PM
mrmint69's Avatar
Is there a brand or type i should get. I guess the 42LB will be the size.
Old Aug 5, 2007 | 01:58 AM
AmericanMuscle33's Avatar
Bosch green-tops are nice.
Old Aug 6, 2007 | 12:16 PM
97WS6Pilot's Avatar
There is a guys selling some 60 pd Mototrons in the For sale section for $300 which is a good deal on some killer injectors that are plug and play with a tune.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
