*** CUSTOM 12" partial well box enclosure... PROGRESS pics inside^^^
Old Jul 30, 2007 | 09:28 PM
fredmr39's Avatar
alright.....some may remember this box I made a couple weeks back: http://www.ls1tech.com/forums/showthread.php?t=733066
I am swapping out my 12" TC-9 for a 12" TC-2000 because the TC-2000 performs much better in sealed applications where the TC-9 likes ported.
I need a new box now though because it is a little small for the TC-2000 -- I would probably keep it still even but the mounting depth is not sufficient (I believe...haven't actually tried yet).
The old box is for sale -- along with the amp rack to the right of it. The long boards everything rests on is not included (unless you really want to pay to ship them as well..much cheaper to purchase your own). Best offer takes it (within reason). Check out thread linked above for more details, or ask questions.
fredmr@gmail.com
[[[F/S thread link to be inserted here]]]
Below is the new box after a couple hours of work...so still obviously a long way to go. The amp will be mounted vertically on the side of the box. In the end....it's going to turn out to be the old box, basically extended downwards. It's kinda going to be built as 2 separate boxes, with a piece of MDT layered between them -- and that will be cutout somewhere along the red circle you can see in the pics. Decided on the 2 piece design for more solid construction, and better use of the space. I was going to just cut out the bottom of the old one, but the side of the box would not look as clean so figured just build another.
Space available will be between 1.3 and 1.6 cubic feet....and if I do end up around 1.6 cu.ft. or more -- I will go ported.....if I can make the port fit...
sorry...a pic of the box underneath would help it make more sense of why the circle cutout will be off set, and how the top piece overlays...etc..
if you're wondering how the back wall will be secured to the bottom...yea so am I -- I meant for it to be back further on the overhang so I could get screws in from the bottom, but that isn't possible now -- so I think I will just add a strip of MDF behind the back wall, screw/glue that into the piece under it and screw/glue if forward into the back wall which will just be glued to the floor... and along the inside of the back wall I'll add a 1x1 of 1.5x1.5 strip of lumber for bracing......
I'm obviously losing the whole nice part of my former idea in retaining almost all of the trunk space...so that kinda sux.. -so sorry for the lame box idea post -- it's mostly for me, so that when I browse the forums I see that this box hasn't been completed, and then I will be motivated...kinda.
Old Jul 30, 2007 | 09:30 PM
fredmr39's Avatar
NEW pics from today.....didn't have much time -- but actually got a good amount done -- everything lines up, now just a matter of cutting, sanding, shaping, bracing, double baffle of some sort etc..... thats the fun stuff tho since it starts to take shape
again, posting this mostly gives me a chance to look at it while I'm at work and give me ideas of how to finish -- so sorry for the many pics
(can see in the pics below the area that will be cutout to reveal the lower chamber necessary for the increased volume... it looks like you can make it bigger, but you really can't easily since the corners of the well are so rounded... )
chamber underneath
- the entire side will be a flat surface for the amp to mount on -- rather than a recessed one like before that allowed me to hide all the carpet seams. I actually still may just make a board to the right of it instead.....but then I will regret not recessing the edges...
Old Jul 31, 2007 | 10:34 PM
fredmr39's Avatar
finally coming together.... comparison shots next to old box, and my TC-2000 arrived today (surprisingly)
took the top off of my new box and set it next to the old... the new one is wider, but less deep due to going in front of the hatch latch.... I'm amazed how similar the two turned out -- especially the angle they slope at
I like how my old 10" looks like an 8" in this pic next to the new 12":
a very impressive amount of suspension/rubber surround:
Old Aug 1, 2007 | 07:22 PM
fredmr39's Avatar
box is done - just needs carpeting, terminal cup and power -- letting it dry, then will carpet and hopefully get completed install pics and opinion on the TC-2000 in this box later tonight
gotta love how I just spread excess liquid nails that squeezes out of the seams all over the box....that's what carpet is for
top piece is a double baffle.....hence the reason it appears to be screwed together in 100 places
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
ddr698
Jan 31, 2015 10:58 AM
HectorM52
Jan 30, 2015 11:34 PM
omarECD
Aug 19, 2002 07:28 AM
