30# accel fuel injectors
Old Jul 29, 2007 | 10:11 PM
lt1loudmouth07
Guest
Posts: n/a
How do i change this in tunercats for my 95 camaro the injector size. i just put in the 30# accell injectors the only thing i did with tunercats is change from 24 to 29.9 in the constant table is that all i do to set the bigger injector size or do i have to do something else
Old Jul 29, 2007 | 10:45 PM
red1997blazer's Avatar
It depends. If the 30# accels are rated at the same psi as your stock injectors then you should be fine. If they're rated 30# at a lower psi you'll have to do some calculations.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
