Permatex Products - How do you choose?
Old Jul 27, 2007 | 10:47 AM
scottso's Avatar
Browsing through these boards and looking over Permatex's website - I still can't make sense of choosing the "right product for the job".
I have a small leak from what initially appears to be where the oil pan meets the timing cover. I see many have used "ultra black". I saw a post regarding a temporary fix smearing some "gray" over the leaky area (after cleaning it of course) - which I may try.
But how do you guys choose your sealer and gasket maker. Even if you read descriptions and open the "PDF" instruction sheets for the products they list (high temp, high temp red, blue, ultra blue, ultra copper, ultra black, gray, etc. - not to mention gasket "dressings") there is a tremendous amount of crossover listed for adhesion, flexibility, vibration, fluid resistence, etc., etc..
How can every one be "superior" or "unsurpassed"?
Old Jul 27, 2007 | 10:59 AM
sabre81's Avatar
why not drop the pan and install a new gasket? Black RTV would be sufficient. Although i LOVE Ultra Copper RTV.
Old Jul 27, 2007 | 02:33 PM
mdacton's Avatar
Use the import grey or The "Right Stuff"
Thats all I use
Old Jul 29, 2007 | 02:44 PM
Kevin97ss's Avatar
Ultra black is best suited for engine oil, Ultra grey for gear oil (Diff. covers), Flange sealant for two smoothe machined surfaces, Ultra copper for exhaust flange, Right Stuff for trans pans.
Old Jul 29, 2007 | 07:55 PM
scottso's Avatar
Is that from experience? You sound confident. I certainly can't get that definitive info from the product descriptions. That's where I have a problem.
Old Aug 1, 2007 | 11:47 AM
Kevin97ss's Avatar
Yes, lots of experience over many years. Also stay away from anything blue or clear, despite their descriptions there not really good for anything.
Yeah, the product descriptions are confusing at best simply because any compound will seal anything for a short amount of time. The correct compound will stay sealed for a really long time.
Old Aug 13, 2007 | 12:30 PM
qboneus's Avatar
Thats all I use
Ditto or +1 on permatex "Right Stuff" Bar none this is the most versatile, useful gasketing out there that "I" have ever found.
I wouldn't buy anything else.
Tal
Old Aug 14, 2007 | 10:27 AM
afr lt1's Avatar
Ultra Copper! I have it exactly in the spot by the timing cover and pan.
n2oblkz
Oct 22, 2015 02:31 PM
CARiD
Sep 30, 2015 05:44 AM
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
