Dyno Tuning & Catalytic converters
Old Jul 20, 2007 | 02:16 PM
Red on Red WS6's Avatar
I have a question regarding the use of a wide band and catalytic converters. On my 96 TA I don't have cats and I also have an O2 bung welded in after the headers for my LM1 wide band, this way I can have the most accurate A/F ratio readings. Now my question is I have a couple friends that want to go to the Dyno and have me adjust there A/F ratio but they still have catalytic converters on there car. Do I need to have a O2 bung welded on to tune them or do I just use the A/F reading with the cats on? I am just not sure how the cats affect A/F ratio.
Old Jul 20, 2007 | 03:12 PM
jay_lt4's Avatar
you should put the wideband o2 close to the front as possible, you dont want to be measuring after the cats
Old Jul 21, 2007 | 01:37 AM
95Blackhawk's Avatar
Cats will affect 02 readings up to around 4K RPM. After that, a stock cat cannot compensate enough and thus the AFR will read essentially right on.
Old Jul 21, 2007 | 08:41 AM
01Z's Avatar
01Z
That's quite interesting. This makes me consider buying a tail pipe O2 sensor clamp for my LM-1. Innovate has instructions on not using the tail pipe clamp for catted cars though. As you say, it is after 4k rpm that the cats have no effect. My a/f read-out from the dyno pull starts at 2200 rpm with a few upward spikes around 3300. After that it's a smooth slope downward.
HarleyZ28
Oct 5, 2015 06:23 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
SC97TA
Sep 15, 2002 01:10 AM
