Cylinder Heads?
Old Jul 15, 2007 | 07:00 PM
Geoffmj's Avatar
Cylinder Heads?
Just looking for some recommendations on a set of heads for the motor im building. 383 w/forged internals. Comp xe284h 240/246 @.50 - .507in .510ex valve lift, 1.5 roller rockers, holley 750dp, rpm airgap intake. Should have about 10.5 to 1 comp ratio. My budget is about $1200-$1300. Any comments or suggestions would be much appreciated. Thanks
Geoff
Old Jul 15, 2007 | 10:24 PM
xpndbl3's Avatar
ARF 195 or 200 eliminators
Old Jul 18, 2007 | 11:31 PM
stanghunter211's Avatar
AFR is the way to go. If you're a little tight on money, trickflow makes some nice heads.
Will
Old Jul 19, 2007 | 12:05 AM
Geoffmj's Avatar
thanks for the reply. I think i probably will spend a bit extra and go with the afr's
Old Jul 19, 2007 | 05:48 AM
Slush92RS's Avatar
I've got the AFR 195's on my 383. They are a great investment. Matter of fact i'm getting ready to pull them off and install a newer set of the 210's (Procharger in my future). I might have a buyer but if you are seriously looking for a set of AFR's i would sell mine for 1000 plus shipping. Mine are 67cc (i believe) with angle plugs and all the accesory holes in the ends.
Old Jul 19, 2007 | 04:37 PM
AutoRoc's Avatar
What's it's intended use? An Air gap intake probably means it's a street car only? Stick car or auto(what stall also?) I'd do AFR 210's with a Vic Jr intake, 1.6 rockers for a bit more lift and let it eat. AFR's look to be $1440 spipped free from Flatlander racing. 195's can be had with a 65cc chamber for more compression but if you do the 210's, they have a 76cc chamber and that will lower compression. Depends on what piston you are working with, etc. They can be milled for a slight fee, same with the intake to match it. Sounds fun, goodluck!
Old Jul 19, 2007 | 04:45 PM
Geoffmj's Avatar
Its going to be a street car, will not see much time at the track. Iv got a built 700r4 with a 3000 stall w 3.73's.
Old Jul 19, 2007 | 05:37 PM
AutoRoc's Avatar
195's with small chamber are a good bet then. I hope you have good tires. ET Radials will either shatter that rear axle or seriously put you back in the seat, either way I'd give them a try on whatever rim you have. If Slush92RS is legit, that might be a killer deal. Do some checking around, etc. Goodluck!
Old Jul 19, 2007 | 07:42 PM
Geoffmj's Avatar
Yeah the rear end is definitly going to be the week link. I do have some decent tires though. Anyway i think im going to buy the heads new and get them shipped with my shortblock, its only a few hundred more and it shouldnt cost me more on shipping. Thanks for the offer though and thanks for the reply's.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
