New times
Old Jun 30, 2007 | 03:12 AM
Z-RATED94's Avatar
New times
Finally was able to take the car to the track. 12.15 at 114mph. 1.65 60ft time. Now I just have to figure out how to break into the 11s. Does the madness ever stop?
Old Jun 30, 2007 | 09:11 AM
Smokn '94 Z's Avatar
Thumbs up
Congrat Rick!! A Yank 4000 stall will get you there!! I am real excited for you and a bit frustrated at the same time........... We did better work to yours then mine...........
You should have told me you were going. I could have went.........
Old Jun 30, 2007 | 11:21 AM
2000GTP's Avatar
Very nice times Rick. Too bad I couldn't have gone yesterday. Maybe next time though. I have to order up some new throttle cables and get the new MAF sensor put in and I should be good to go.
Old Jun 30, 2007 | 11:29 AM
Z-RATED94's Avatar
Thanks guys, and thanks again Eddie for doing the work to the car. If I would have known, I would have called you. I want to let you drive it so I can watch it go down the track. PS, I guess it was worth the extra wait for the Joe O. cam.
Old Jun 30, 2007 | 11:33 AM
mdacton's Avatar
What is the wt. of the car?
You have more power somewhere.......or something isn't right, unless its really heavy
I have run way quicker than that@ 3200# and wayyy less h.p.
Old Jun 30, 2007 | 11:36 AM
Z-RATED94's Avatar
Full weight (options loaded car). And over half a tank of gas. Very small cam. Should my ET be better compared to my MPH? Thanks
Old Jun 30, 2007 | 11:39 AM
mdacton's Avatar
get it on a scale.....
114 m.p.h you could probly get 11.70 11.80 with little effort.......
You have good 60'......so a little work, a really good converter that works well I say consistant hi 11's is no prob.
Just tweak all the little stuff now
Old Jun 30, 2007 | 11:48 AM
Z-RATED94's Avatar
Thanks, I'm thinking about a 3600 Yank now. And the 2-3 shift has to come down a little. Maybe a 100 or 200 rpm. Seemed to lag for an instant where its set right now.
Old Jun 30, 2007 | 11:52 AM
mdacton's Avatar
you get all that little stuff figured out, you will be amazed.....
Its got plenty left in it so keep working on it.
Congrats.
Old Jun 30, 2007 | 12:59 PM
Thumbs up
It was worth all the work and your stitches.. Like I said a Yank 3600 might be great but I think the 4000 would be better. Javier on this board has basically your set up and runs the 4000 I believe. I might be wrong. I think the car with a better converter is a 11.70 car with the full weight.
Call me NEXT TIME!!
Old Jun 30, 2007 | 01:35 PM
Z-RATED94's Avatar
Call me NEXT TIME!!
Eddie, I'm thinking no bigger than a 3600 because I'm going to spray a 100 shot next year, and don't want to run out of gear. Plus I don't know how a 4000 would be on the street. And thanks mdacton.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
