I cant find a good cold air intake anywhere!!
You dont need one. The stock Camaro TPI intake is one of the best setups out there. The best thing you can do it cut out the plastic pieces underneath the air filters to make them fully open.
its funny you say the cutting thing... i didnt even read about it on here i was putting in some filters and i kept diggin deeper i looked at my buddy we just smiled and started cutting stuff haha... would the ram air be more afficiant than stock??
the "ram air" I mentioned involves ducts that go down from the stock air boxes(with bottoms cut off), down to behind the foglight openings
That is contrary to the results most people have come to after back dyno tests, one with the airbox connected and one without. The stock TPI intake is extremely restrictive. Look at how narrow the tiniest part of the "neck" going from the airbox to the TB is. At WOT the "neck" can also be sucked flat.
stick a filter on the end of the TB.....the stock box is junk
you WILL pick up by just using the filter on the end, I don't want to hear any crap about hot air either......More air is better than less, and air inlet temps are not going to be as much of a difference for the power you gain by having more air.
