low Antifreeze light comes on & stays on
Old Jun 17, 2007 | 06:20 AM
ItalianSS's Avatar
Hey guys, this is really bugging the heck out of me. Out of no where, my antifreeze light comes on one day. At first i didn't even know what that light on my dash was for. After reading my service manual, and finding out what it's for, it says that the fluid level might be low. After topping it off. It still stayed on. There were days when i turned the car on, let it run for a few minutes, then shut the car off restarted it and the light would be gone. Now, it stays on for good. I'm a little worried, but at the same time it could be something stupid. Does anyone think it could be the antifreeze cap, maybe just replace it? Or maybe i need to change the fluid? Last time i changed the fluid was maybe a year or two ago. What do you guys think. Anyone have this dumb problem?
Old Jun 17, 2007 | 06:38 AM
ItalianSS's Avatar
Someone told me it could be a sensor? I really hope that's what it is. But how do you know if the sensor is good to begin with? I know i have disconnected the sensor right below the cap, and the light goes off... but i don't know if that's a good thing or whatever.
Old Jun 17, 2007 | 09:39 AM
angel71rs's Avatar
Yeah, you just disconnect that sensor and you're fine. I did it on my SS, will do it on my Z if the thing gives me problems.
Old Jun 17, 2007 | 01:14 PM
Zitty'sZ's Avatar
The coolant level sensor is a problem with these cars . It seems everyone has had a problem with theirs including myself. It is located below your radiator cap about 6-8 inches down. You could try cleaning it or just replace it, just lower the coolant some in the radiator first before removing it. Good luck!
Old Jun 17, 2007 | 04:35 PM
2001NBMZ28's Avatar
My car doesn't even have one - think GM took them off our cars starting in '00.
Old Jun 18, 2007 | 07:40 AM
AL SS590 M6's Avatar
Because they are junk and was causing too much warantee cost.
Old Jun 18, 2007 | 02:45 PM
ItalianSS's Avatar
Really? Just disconnect it? I mean, cause i disconnected for like a week, but then i though... what if i really need it.
Anyways, how would i change it if i wanted to?
Thanks again guys, for all the help.
Old Jun 18, 2007 | 03:11 PM
2001NBMZ28's Avatar
It's easy to change, just drain the coolant to a level below the sensor and replace it - they go for about $57 GM list at the dealer, cheaper from a sponsor/local parts store. I have PN 10096163 written down but double check.
Old Jun 19, 2007 | 01:05 PM
ItalianSS's Avatar
Hey thanks a lot...
Magenta_Hearts
Mar 29, 2017 08:54 PM
warmeck
Mar 1, 2015 08:47 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
squarehead
Jan 15, 2015 07:02 PM
