Bench Bleed new Slave?
Old May 23, 2007 | 02:52 PM
phoenix1987's Avatar
I have my master out and have a brand new slave (GM). Should I just hook the master up to slave and bleed it on my bench while they are out? I have to bleed my master anyway.
So can I bench bleed the two of the while hooked up to each other, then disconnect, then hook back together when in the car? Sorry, I am new to this and don't wanna take the tranny out again.
Old May 23, 2007 | 06:06 PM
blackrat's Avatar
I would do them individually just to play it safe.
Old May 25, 2007 | 06:19 PM
OBE1 95Z28's Avatar
For us to help you, you need to tell us what year car you have. Fourth Gen 93 -97 master/slave can be removed installed without removing the tranny. Also the master/slave can be remove/installed as an assembly, so you can bench bleed it or bleed it on the car.
Formula Steve
Sep 19, 2023 08:31 AM
1bad427ls1
Sep 23, 2015 01:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
canuck94z28
Aug 19, 2015 05:50 PM
MikeWhitener
Aug 2, 2015 06:17 PM
