'02 SS Springs
Old May 20, 2007 | 09:26 PM
ChevalierSS's Avatar
'02 SS Springs
What kind of front springs came on an '02 SS, what is the spring rate?
Someone is giving me a set, and I was going to use them as a drop spring on my 95 Trans Am, but I'm only going to use them if they are a stiffer spring.
Old May 20, 2007 | 09:33 PM
Greed4Speed's Avatar
V8 98-02 292 front 114 rear
V8 93-97 310 front 110 rear
Not worth the change. They'll drop, but only because the LT1 is heavier than the LS1
Old May 21, 2007 | 06:04 AM
That's what I thought, but I thought maybe the SS used stiffer springs than the Z28.
Old May 21, 2007 | 06:18 AM
JakeRobb's Avatar
Super Moderator
I beleive that's correct. I don't have the spring rates, though. Anyone?
Old May 21, 2007 | 12:21 PM
ConElite's Avatar
I thought they were the 1LE Springs. The main reason why the SS handles better is b/c of the 32mm sway bar up front.
Old May 21, 2007 | 04:22 PM
JakeRobb's Avatar
Super Moderator
Wider, lower-profile tires help too.
Old May 21, 2007 | 04:43 PM
ConElite's Avatar
Amen,
Yeah I got the 1LE SB up front (32mm). Poly Bushings all around on the end links and Pro-Kit. Car handles pretty damn well.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
