LIttle Help
Old May 14, 2007 | 10:06 PM
jsviking08's Avatar
LIttle Help
I have a 82 chevy BB 454. It runs well but it has a crack in the block. What is the best thing to do to fix this problem except buying a whole new engine?
Old May 14, 2007 | 10:45 PM
windsma's Avatar
where is it cracked.
used 454 block couldnt cost that much.
lots of chevy trucks used them.
Old May 18, 2007 | 01:04 PM
rhamm1320's Avatar
They are getting pretty expensive in general, about 5 bills.
If the crack is on the outside in a non stressed area (not near the mounts or bellhousing), you can epoxy it. I have seen this used to cure external water leaks.
If its inside in the valley, mains or deck surface, its probably toast.
