Removing Various Body Parts
Old May 5, 2007 | 04:41 PM
1LESSZ28's Avatar
on a car lol..
How do you remove the spoiler on a 97 z28?
How do you remove the air diverters in a camaro hood?
(need to paint them)
How do you remove the sail panels?
How do you remove the side mirrors?
Thanks in advance
Old May 5, 2007 | 07:27 PM
Don350k's Avatar
on a car lol..
4 bolts under the trim on the hatch i belive0
Never tried, belived plastic welded in but could be wrong
sail panels?
Bolts behind top trimpiece of door triangfle shaped
Thanks in advance
Don
Old May 5, 2007 | 07:32 PM
1LESSZ28's Avatar
thanks. the sail panels are the triangular between the door and rear window.
are there only two bolts for the mirrors or is there more?
for removing the spoiler does the plastic on the hatch just pull off?
Old May 5, 2007 | 07:39 PM
Angelis83LT's Avatar
for sail panels inside or outside? if outside I believe those are part of the body and you have to actually cut them out with a torch / plasma cutter.
Inside, I believe it's just the coat hanger screw and then they slide up?
I could be wrong though... But I am pretty sure on the outside sail panel part.
Old May 5, 2007 | 07:40 PM
deputydough's Avatar
on the mirror there should be screws holding the plastic triangle and then three bolts holding mirroe and a wiring harness for the power mirror to unplug. never pulled the triangle piece between window and rear window.
Old May 5, 2007 | 07:51 PM
1LESSZ28's Avatar
well I think they are referred to as sail panels I could be wrong though..
if you look at a camaro from the side its the black triangle on the outside between the door glass and the rear hatch. not really a panel just a piece of ?plastic
Old May 7, 2007 | 02:00 AM
Don350k's Avatar
where the speaker is under?? lol if so ill have 2 look, i think its just held in with clips and pulls out but dont quote me on that, ill see if i remember 2 look 2morrow
Don
Old May 7, 2007 | 08:52 AM
pcgamer4life's Avatar
The hood louvers on a stock 4th gen hood are held on by either 2 or 4 flimsy nuts on the underside of the hood, covered up by the hood insulator. I want to say they're pretty big, maybe 15 or 18mm, and they might break if you're not careful when unboting them.
Old May 13, 2007 | 02:32 PM
sn8ke eatr's Avatar
none of the stuff is honetly that hard.. just use your head, youll find the nuts on the underside of the panel usually just take your time and dont break stuff and youll be fine
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
jwright3SS
Jul 30, 2002 03:49 PM
