385 LE2 Setup, 466rwhp 449rwtq
Thanks Bret, Lloyd, Ion and Don
466rwhp 449rwtq (A/F 10.5, 32* timing)
450rwhp with Ion mail order tune
385 LT1
11.9 compression
Eagle crank, eagle rods, Mahle pistons
Le2 Heads
BRE LE3 cam
LE ported intake
58mm , 42 svo's, under drive, K&N CAI, SLP 85mm MAF,
Pace Longtubes, y-pipe, open cut out
160 stat, electric water pump
OBD I conversion, Ion mail order tune, Dynoed tuned by myself
MSD wires, ngk tr55's, Gm opti
I'll post a graph tomorrow, need a scanner.
385 LT1
11.9 compression
Le2 Heads
BRE LE3 cam
LE ported intake
385 LT1
11.9 compression
Le2 Heads
BRE LE3 cam
LE ported intake
385 LT1
11.9 compression
Le2 Heads
BRE LE3 cam
LE ported intake
High compression, full bolt-on's
Ask lloyd or Bret EVERY setup i build puts out better than average numbers, because i spend the time and cash on supporting mods and making sure everything works together.
415/381 Le1.5 355 (UNported intake)
419/393 Le2 stock 350 (Unported Intake)
403/383 Le1.5 stock 350 (unported Intake)
401/376 Le1 cc306 stock 350 (Unported Intake)
466/449 Le2 385 (Ported Intake, wow what a difference)
Too bad this isn't my own personal setup, mine is going to to be better, higher compression, bigger cam and a single plane 500hp here i come, with a hydro.. Should be running with in 2 months, wheres that intake Bret??
You just made my day! I'll be running 12.5:1 on LE2/LE3 383, so I like your numbers. A little inspiration not to skimp anywhere.
I've got mech w/p, no underdrive, and no cutout. IE: did not do 'all the little things' so I can't really expect to match your numbers. Still, I think that's a new high water mark. Any idea what all that is worth to you? Maybe 20?
Did you A-B test the cutout, and if so what is your exhaust?
How did you get 11.9:1 with the Mahle pistons on a 385? I take it your head gasket/quench is bigger than ideal, or you reworked the pistons?
Why was OBD 1 conversion applicable for a 1994 car, which is OBD1 to begin with?
Dynojet?
Thanks.
Dynojet?
Thanks.
