Valve spacing and dowel shift, can someone explain??
Old Apr 20, 2007 | 11:37 AM
95ttoplt1's Avatar
Hey this is kinda funny but the heads I got advertise a 60-40 valve placement and a .085 dowel shift. I got the heads at the recommendation of the Guy's at AI, and I would think they know what they are doing.
But what does the 60-40 and dowel shift mean??
Old Apr 20, 2007 | 11:59 AM
SStrokerAce's Avatar
60-40.... Piston Manufactures are the best at showing how you get this.
Basically what that means is how much of a shift you have from the centerline of the piston. The standard placement of the centerline of the exhaust valves is 1.000" over from the center of the piston and .850" over for the intake.
A 60-40 shift takes the intake valve and moves it .040" closer to the center (.810") and the exhaust .060" farther away (1.060")
A Dowel shift is usually either using a offset dowel pin that moves the head over the set amount or you have the heads dowel holes moved over that amount to locate the intake valves that amount away from the cylinder wall.
Different motors need it done different ways but all this applies for the SBC/LT1. A LS1 can only be "shifted" with offset dowel pins, which are a PITA to make. Ask me how I know ;-)
One other little tid bit is on some motors you don't always want to offset the intake farther away from the bore but offset it CLOSER, and no it's not for a "blower motor".
Bret
Old Apr 20, 2007 | 12:52 PM
95ttoplt1's Avatar
Bret
Interesting, I had seen the offset dowel for sale in summit and always wondered the purpose.
So the All-pro heads I got have the dowel pin holes themselves moved?
Wouldn't this mess with the head bolt hole alighment and everything else?
Which way are they shifted? Toward the intake manifold or toward the headers??
Thanks for the explaination!!
Old Apr 20, 2007 | 02:06 PM
95ttoplt1's Avatar
Here the heads I got, they are CNC'ed to 255 and on the way to AI for touching up and matching to the Vic-E intake
I got a set of J2K Jesels with the heads as well so I am slowly getting a decent combo together
Old Apr 20, 2007 | 02:49 PM
95ttoplt1's Avatar
Piston manufactures have good pictures, this one is from JE.
Old Apr 20, 2007 | 07:08 PM
OldSStroker's Avatar
Ask All-Pro
Maybe a little. You might have to enlarge a bolt hole or two.
Which way are they shifted? Toward the intake manifold or toward the heades??
Normally it would be shifted front/back, not side to side.
Old Apr 20, 2007 | 07:20 PM
Masnart39's Avatar
They'll bolt up just fine. Just make sure you mock up your rocker system as soon as you get the heads back. It took T&D 3 trys to get the right stands for the last set I did.
Old Apr 20, 2007 | 08:25 PM
MachinistOne's Avatar
Ya sure about that
They shift the heads towards the lifter valley, moving the valves more into the center of the bore. It is not a symmetrical valve motor, if you shift the heads front to back you are moving two valves closer to the center of the bore, but moving the other two closer to the cylinder wall.
Old Apr 20, 2007 | 09:24 PM
Masnart39's Avatar
Originally Posted by MachinistOne
Ya sure about that
Yep.... which reminds me, make sure they check to see if the intake face has been milled back to compensate. Otherwise you end up with the manifold ends about a half inch above the china rails and the bolt holes & ports out of alignment.
Old Apr 21, 2007 | 02:28 AM
95ttoplt1's Avatar
Ya sure about that
That is correct, they are moved .085 toward the lifter valley, I found a little write up from a guy building a motor with my exact heads.
I bought these heads used with the rockers they were running and everything so it should all bolt right up, hopefully
Old Apr 21, 2007 | 01:36 PM
Ya sure about that
DUH! Yep, I was thinking about symmetrical heads. Thanks for the correction!
Of course, you could always move the bores instead of the heads.
Old Apr 21, 2007 | 01:43 PM
95ttoplt1's Avatar
Ah I think I will just be indexing them to where they should be and leave it at that. I wanna make it a monster but I still have a budget.
Old Apr 21, 2007 | 02:02 PM
We had an apprentice at the shop for a while, and he was being trained on the boring bar - left him alone after doing the first 3 cylinders and somehow he didn't center the head over the 4th bore right and came out with a nice oval The head is auto-centering, so I am still not sure how he managed to do that one...
Old Apr 21, 2007 | 02:48 PM
95ttoplt1's Avatar
Nice, some people will always amaze you with there inability's
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
69z-28
Jan 29, 2016 10:46 PM
BigWil
Mar 29, 2015 12:24 PM
Snoman73
Nov 17, 2014 07:22 PM
