What's the cost and difficulty level of....
What's the cost and difficulty level of swapping out an A4 tranny, and replacing it with an M6 in a Z28?
I've got a guy wanting to buy my car, but he wants to know if it's expensive, and you have to hack a bunch of crap up to swap it in.
From what I was calculating I was expecting to spend $2300 after labor. It's not that common of a swap. Then you still have the 2.73/3.23 rear end and automatic radiator, etc.
It really depends on how far you want to go and how much of the work you can do. 99% of the parts can be purchased over the counter if desired, or you can try saving some green and buying used stuff. I went the new route as well as a built tranny from D&D Performance and it ended up being almost 4k
. Most people on here will claim that they only spent 1.5-2k on their conversion only to find that they bought a junk tranny and have to fork another 1.5k a few months later. I just decided to bite the bullit and do things right the first time. As far as price, I'd say 2k-4k depending upon needs and desires of the owner. If he doesn't mind used and doesn't need a performance clutch 2k is very doable. But he if is **** like me and needs something that can take a beating, lean closer to 3-4k.
The level of difficulty isn't hard at all. If s/he can drop a tranny and change a clutch, they should be able to do the swap. Most everything is a straight bolt-in with the exceptiion of cutting a hole for the shifter and clutch master cylinder. The wiring is straight forward as well and can be accomplished in about an hour.
. Most people on here will claim that they only spent 1.5-2k on their conversion only to find that they bought a junk tranny and have to fork another 1.5k a few months later. I just decided to bite the bullit and do things right the first time. As far as price, I'd say 2k-4k depending upon needs and desires of the owner. If he doesn't mind used and doesn't need a performance clutch 2k is very doable. But he if is **** like me and needs something that can take a beating, lean closer to 3-4k.The level of difficulty isn't hard at all. If s/he can drop a tranny and change a clutch, they should be able to do the swap. Most everything is a straight bolt-in with the exceptiion of cutting a hole for the shifter and clutch master cylinder. The wiring is straight forward as well and can be accomplished in about an hour.
I did it to my old Formula (a '94) back in '02. I also had the luxury of the donor car being parked 15 feet away. I relied heavily on a site that had a step by step break down of it it including all the wiring changes necessary. I'm sure it's still around.
I think the heads/cam swap I did was more difficult and involving.
As long as you take your time, it is a fairly straight-forward swap. I'm not sure what parts go for now, I'd guess $2000 or so.
I converted my 91 Firebird to a T-56. It is pretty straight forward. What gave me the biggest pain in my *** was drilling out and lining up the holes for the master cylinder. I did this with the brake booster in place though. I give this job a 6.5-10 for difficulty.
Zach
Zach
if you doit yourself there is NO WAY it will cost 4700. You can get a wrecked donor car and part out what u dont need or find someone who did a TH350/400 swap and get buy all their stuff. From what I've seen its not THAT hard to do. I think there is a place online that sells a kit with everything needed for like 2100-2300.
Not that hard, took me 12 hours on my back with minimal tools.
Cost: Got a complete tranny, clutch, pedals, shifter, etc for $1500. Sold my A4 with converter for $900.
So for me $600 and 12 hours of my own labor.
This was back in 2001 though.
Doug D
Doug D
Sep 11, 2015 09:44 AM
