Guy's running 9 inch rears.......
Old Nov 25, 2002 | 12:38 PM
LT1S10's Avatar
What are you running for a 3rd member?
Nodular Case? Standard Case?
Spool? Locker? Auburn? Traction Loc? TrueTrac?
What gears?
Pinion Support?
How much horsepower is your combo?
How do you like it, as far as streetability, if that applys.......
Thanks guys?
Trying to decide on one...........
Mike
Old Nov 25, 2002 | 08:34 PM
ru2slo_99's Avatar
My car has a 9 inch in it. I have not driven it yet. I believe it has a nodular case. It has 3.90 gears, detroit locker, with 35 spline mark williams axles. My car made 466 rwhp before I got it. I hope it holds up to my abuses.
Old Nov 25, 2002 | 09:37 PM
Stephen 87 IROC's Avatar
1970 F-100 housing
Standard case (never checked the date code)
Spool
Strange 31 spline axles
4.56 gears of unknown origin
No problems yet.
Old Nov 25, 2002 | 10:02 PM
Guido's Avatar
Allstar nodular case
stock pinion support
richmond 3.50's
31 spline axles
auburn pro posi
its totally streetable however this winter Im pulling the auburn for a spool
car is more geared towards the 1/4
Old Nov 25, 2002 | 10:17 PM
chevyguy3's Avatar
Nodular case
spool
35 spline gun drilled/star flanged axles
billet daytona style pinion support
moser yoke
4.33 gears (about to change)
5/8 wheel studs
drives fine on the street
~550hp NA, another 200-250 on the bottle
Old Nov 26, 2002 | 07:24 AM
Brady's Avatar
Mark Williams Nodular Case
Moser Spool
3.50 gears
Billet pinion support
I broke a stock case and 3 teeth on the pinion gear on my last 9" setup, so I went Nodular.
laterz
...Brady
Old Nov 27, 2002 | 06:44 PM
zturbo's Avatar
Moser Nodular Iron.
Spool
What gears?
3.50 gears nothing fancy, I am thinking of going to a higher gear so i can get the pro series gears.
Pinion Support?
Moser billet alum
Hopefully alot shooting for the 4 digit range
Not sure yet as I used to run a 12 bolt before the buildup. I will say it is a major PITA to push the car into and out of the shop when doing things cause of the spool.
Currently running 40 spline axles but will be getting a new set of gun drilled axles to lighten up the rear a bit as well as narrowing the housing.
Steven
Old Nov 30, 2002 | 07:17 AM
FASTFATBOY's Avatar
I have a 9 inch, a truck case, the one right under a nodular case. Has a daytona pinion bearing support, truck yolk, 4.10 gear, old style detroit locker. I make around 380 RWHP(never dynoed, guessing from my 89.1 MPH 1/8 mile speed through closed exhaust@3800 lbs). Im my opinion do not buy a locker as I have. It is very nasty on the sreet moreso with a manual tranny car. They do make a "soft locker" now as I understand. The factory Trac-LOC posi's are very strong if built right up to around 450RWHP with a manual tranny and even more with an automatic.
David
Old Nov 30, 2002 | 05:43 PM
Tweaked Zed's Avatar
If you're running a T56, do NOT use a grey cast case. They just won't hold up. At least mine didn't. Split the case in half and pulled the pinion out the front. Luckily didn't make much of a mess.....except for the starting line. Now, there are cases out there that are not labelled with a big "N", but do have two vertical ribs above the pinion support. I was told these are also nodular cases, but were not identified as such. Might find one of those cheap if you're lucky.
Nodular case
Detroit locker(new improved)
3.89 Motive gears
Ford SVO Al pinion support
1.57 60'
Old Dec 2, 2002 | 11:02 AM
Pro Stock John's Avatar
98 Formula:
Strange nodular center
Strange 4.11's
Tractech soft locker
Moser 31 Spline axles
-Locker never really makes that much noise, it will ratchet or even sometimes drag a tire on tight turns but only noticeable on grass or gravel.
-I don't consider a spool to be a street application but that's just me.
-I have been in a 98TA M6 with a regular locker and it was pretty noticeable.
Old Dec 3, 2002 | 09:49 PM
86 Iroc HOTROD's Avatar
I have 2
1:
Moser Nodular case
FULL spool
4.86 gear
31 spline axles
2:
Standard ford
mini spool
3.73 gear
I'm not sure about the horsepower, but check sig for times, as far as street abilaty I dont mind the spool, I never know it's back there unless I make a sharp u-turn or am in gravel or dirt, and then its only a little chirping, and I dont even have power steering and it's not that noticible.
Tweaked Zed said
"Now, there are cases out there that are not labelled with a big "N", but do have two vertical ribs above the pinion support. I was told these are also nodular cases, but were not identified as such. Might find one of those cheap if you're lucky."
He's right the two vertical ribs do indicate a Nodular case, but these are factory ford Nodular cases, there are not many left in circulation making them hard to find and very expensive ,unless you can find someone who dosent know what they have.
Also dont get the lowest gear you can live with for great performance, as I did. I went with a 4.86 when I ordered my rear because all the tracks around here are 1/8th mi., drivability suffered greatly, 55mph was about 4500rpms, I actually picked up on Nitrous when I went to a 3.73 gear, I lost less than a tenth on motor, but I picked up .15 on motor and .20 on Nitrous when I went from 28x10's to 26x10's, so actually now with 26x10's and a 3.73 I run faster on motor and nitrous than with a 4.86 and 28x10's, and the drivabilty improvement from 4.86 to 3.73 was tremendous.
All i'm saying is do your homework when choosing a gear, if you want a Nodular case I suggest buying a standard one and trying stock gears first to see what works the best with your combo. then when you find a combo that works well buy a Nodular one in the same configuration, and save those $50 standard junkyard cases for spares
The reason I went with 31 spline axles is most factory ford 9in.'s had 31 spline carriers, this way I would have no prob using the "junkyard" cases
Hope this helps
Old Dec 3, 2002 | 11:57 PM
I'm not sure about the vertical ribs as a way of identifying the case but there are nodular cases without the large N on the outside. They will still have a small N on the inside of the case and are just as good and easier to find.
Just stay away from the WAR casting.
Old Dec 4, 2002 | 11:34 PM
BlackRocketZ's Avatar
Factory Nodular housing. 4.86 gears, spool, Billet pinion support. 525hp, Th400 with brake. So far so good.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TitoPR221
Jan 2, 2015 03:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Sep 5, 2002 05:45 PM
Red97LT1
Aug 7, 2002 05:45 PM
