rough idea for shift point built 700r4
Old Apr 17, 2007 | 03:16 PM
confused327's Avatar
i'm getting my trans built and the shop wants to know what shift point i want. HERE is my setup. i'm thinking around 5800, sound about right?
Old Apr 18, 2007 | 04:16 AM
Pro Built Automatics's Avatar
With the duration at .050 of 215 degrees, 650 cfm carb, the shift points should be around 5,200 rpm at the maximum, maybe even less. The rpm air gap is not going to help you here, the performer, yes, rpm performer, no. The cam and carb cfm are too small for the rpm performer.
Old Apr 18, 2007 | 11:40 PM
the specs of a stock LT1 cam are around 201/208, i don't see how my bigger cam would want a lower shift point.
something in the cc503 range will probably find it's way in there later on, thats the reason for the rpm air gap.
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
