Old 04-10-2007, 01:46 PM   #1
Rice Killer87
Tilt wheel.
I am really excited about the new Camaro to come out and just thought about one thing.
The new mustangs have the IMPORT style AFAIC,where the whole column goes up and down like 2" instead of just the steering wheel. I F'in hate that and if GM puts them in the new Camaro I will tell you right now I WILL NOT be buying one just for that factor alone. It makes the 'stang so much harder and more of a PITA for me to drive b/c of my long arms.
Please dont screw up like they did.
__________________
2000 Camaro SS A4 # 3535,milled LS6 heads (to 62cc's) with Cometic .045,custom 230/236 .591/.600-112 cam,Hooker LT's with TSP catted Y,LS6 intake,3400 Vig. stall
'86 IROC-Z clone race car, 565/TH400 5.68@120 off early and on the brakes
Rice Killer87 is offline   Reply With Quote
Old 04-11-2007, 01:02 PM   #2
EllwynX
EllwynX's Avatar
Send a message via AIM to EllwynX Send a message via Yahoo to EllwynX
I'd like to see tilt/telescoping wheel.
Currently on my Aveo I sit all the way back. The legroom is fine; perfect at that point actually. But my arms are pretty far from the steering wheel.
EllwynX is offline   Reply With Quote
Old 04-22-2007, 01:55 AM   #3
Bayer-Z28
Bayer-Z28's Avatar
Send a message via AIM to Bayer-Z28 Send a message via MSN to Bayer-Z28 Send a message via Yahoo to Bayer-Z28
IMO, I can't STAND that whole column up and down thing. I'd rather the type they have now. The bottom half of the steering column could get in the way of my knees. (I'm tall @ 6'3")
I just hope they don't make the wheel itself too big. My 2000 could use a slightly smaller wheel. The top half blocks some of the road, the left most view out of the windshield. -The centerlines or the edge lines. The wheel should not obstruct the view of the road.
__________________
2000 Z28 M6 ......H/C/I, susp, exh -LOTS More!-
1995 Ford F150 Extended Cab, spray on bed liner, 5.0L V8
2006 Yamaha YFZ450 !Lid, !SA, Stainless oil filter, jetting, Cam mod , AC Nerfs, HMF Full pipe, Graphics..
Listen to the CamaroZ28.com Podcast!!
Bayer-Z28 is offline   Reply With Quote
Old 04-22-2007, 08:09 AM   #4
fastball
Most likely it will be the whole column tilting. They will have a telescopic feature as well, and the only way to make a tilt/telescopic wheel with an airbag is to make the whole column adjust. Keep in mind, the old "tilt wheel" that your 4th gen and older Camaros have is old GM. That's all going away. I prefer having an infinite range anyway, instead of 6 preset notches.
I think it's quite shallow for anyone to refuse to buy a great car simply because they don't like the new tilt column design. Try it, I'm sure once you get used to it, you'll wonder what you liked about the old design to begin with.
fastball is offline   Reply With Quote
Old 04-24-2007, 01:24 PM   #5
Big Als Z
I have colum tilt and telescoping wheel, as well as adjustable pedals and 6 way power seat....if you cant get comfortable with one of these variations, then I dont know what to tell you.
I get in my 72, and there are no adjustments...my seat is already as far back as it can go.
__________________
2009 Malibu LT 2.4: My NEW Ride! Yeah...no Camaro...I know I know...
1987 Camaro Z28
1972 Camaro RS: It's easy being green
Mod @ GMInsidenews.com
Big Als Z is offline   Reply With Quote
Old 04-24-2007, 02:53 PM   #6
Rice Killer87
Quote:
How do you know its great? Its not even out yet.
My gf has an 05 stang and I do A LOT of racing stripes on BRAND NEW ones almost weekly,so Ive been driving them quit a bit and I still cant do it. Evidently you dont have long arms like me,thats what makes it uncomfortable for me no matter HOW its adjusted. Even w/ the damn thing all the way down,it still feels like im driving a SCHOOL BUS. The steering wheel sits too high and blocks too much of my vision which is another reason I cant stand it. I have to drive w/ my hands either at 10 and 2 like an old fart (still in my line of sight) or hold at 9 and 3 or even lower just so I can see where im going.
I could care less about a telescoping column,thats why the F'ing seat moves forward and backward.
__________________
Old 04-24-2007, 11:27 PM   #7
bombebomb
bombebomb's Avatar
i like it the way it is now, hopefully its the same.
__________________
94' z28 lt1 383, A4, 160 t-stat, CAI,Spohn LCA's,Nittos 555R,3.73's,Tuned, e-waterpump, TD's magnaflow, Pacesetter LT's, Stock Heads,
Compstar 6"rod, compstar 3.75 crank,JE pistons,lunati cam, 1.6pro mag
Nitrous hardend rings, 4bolt splayed. 12.2 @114
www.L99Tech.com
bombebomb is offline   Reply With Quote
Old 04-25-2007, 12:12 AM   #8
EllwynX
EllwynX's Avatar
Quote:
So when you have the seat set perfect for your legs/feet to reach the pedals, but the steering wheel is either a bit too close or too far... You don't see that as a reason to have a telescoping steering wheel?
The seats movement is for the comfort of your legs, telescoping wheel is for the arms.
I for one hope the telescoping wheel becomes more standard in all cars.
Old 04-25-2007, 09:23 AM   #9
fastball
Because the style of tilt/telescope design that will be in the Camaro is the same thats been in every European car for 20 years and that's in most Japanese cars now. I've driven Hondas and Lexus' with it. My Prelude has a tilt column without the telescope, and I like it much more than the archaic tilt design from GM of old. There aren't stupid notches that limit where your wheel goes - it's perfectly adjustable to where you like it exactly.
Go drive a 3-series, Accord, Acura TL, or Lexus IS250. You'll understand why Japan and Germany have been getting glowing reviews for years for ergonomics and the ability for any driver to fit the seat, wheel, and mirrors to the perfect position, while GM has always gotten bad reviews.
It's about time they got with modern ergonomic interior design.
Old 04-26-2007, 10:28 AM   #10
blckbrd84
I hope it uses one similar to the GTO's. I love the fact that I can move the GTO so it's at the perfect height to not rub my legs yet it's low and sits straight. I hate the old style in my WS.6 as to get it to not rub my legs I have to have it tilted up slightly where it doesn't sit straight.
Plus with the telescope ala GTO it's so much easier to get it so you can see and yet you can comfortably reach it even with the seat back far.
__________________
2002 BSM Trans Am WS-6
346 LS1, 6spd, T-tops, TCS, Hurst
Stock: 13.455@105.39 w/ 2.129 60'
Mods: 12.44@113 w/ 1.83 60'
2004 QSM GTO
346 LS1, 6spd
Stock: 13.7@102
http://members.cardomain.com/silvertaws6
blckbrd84 is offline   Reply With Quote
Old 04-30-2007, 10:44 AM   #11
Rice Killer87
I havent driven a GTO so I wasnt aware that they had a new style tilt column...sounds like exactly what I need,hopefully they build it w/ this.
__________________
Old 08-25-2007, 11:55 AM   #12
GTOJack
The only way I'll be able to fit in a new Camaro is with a tilt/telescopic steering wheel. Otherwise, my beer belly will be in way. I fit OK in my past 04 and 05 GTOs. Hopefully, GM will use the same system in the new Camaro.
__________________
Was TA Jack
2008 black Mustang GT Bullitt
2007 Silverado Classic 2500 CCLB LT3 Dmax/Ally
2007 Pontiac Grand Prix
GTOJack is offline   Reply With Quote
Old 10-19-2007, 04:29 PM   #13
90 Z28SS
Wait for the G8's to get here . Whatever it has , is a sure bet the Maro will have the same thing . All Zeta's should pretty much share the same steering column in different trim levels . Which means , the column should be very GTO like , as the G8's does tilt and telescope .
__________________
94 Z/28-twin turbo LS1 project -jackstand queen till sometime on 07
2005 Cobalt SS supercharged- 13.648@102.99
90 Z28SS is offline   Reply With Quote
Old 10-22-2007, 11:27 AM   #14
97QuasarBlue3.8
97QuasarBlue3.8's Avatar
What are you, 3' tall? A midget?
At almost 6'5" the Mustang is one of the few cars where the seat, if pushed all the way back, is TOO FAR back for me. I have to have the seat up a couple of clicks up in my GTI too, or else I can barely push the clutch in all the way. The tilt/telescope wheel is the greatest invention for tall people...We can have the seat back and have the wheel come with us, or stay far away if our arms are really long.
The 4th gen was a damn nightmare for ergonomics and safety...roofline too close to a tall person's head, dashboard too close to the knees, steering wheel (when tilted down) had the airbag aimed at a person's belly--not good--or at a person's face if they needed to tilt it up for leg room--also not good. The 6-way seats were its only saving grace...I could gangster lean just enough to be far enough away from the roofline and steering wheel and still manage to be comfortable.
I fail to see how greater adjustability is bad...
__________________
2009 Colorado Crew Z71 4x4 | 2008 Volkswagen GLI | And the Ducati twins.
97QuasarBlue3.8 is offline   Reply With Quote
Old 10-22-2007, 01:52 PM   #15
Rampant
Rampant's Avatar
Quote:
+1. I would be very disappointed if it didn't come with a tilt/telescope (I am 6'2" with long legs and my knees/legs always seem to hit the bottom of steering wheels).
Rampant is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
