3800 SC injectors?
Old Apr 8, 2007 | 09:47 PM
mdenz3's Avatar
3800 SC injectors?
I did a search and found nothing, so...
Is it possible to use the stock injectors out of a 3800 series II supercharged engine in a LT1? My plan was to get two cheap sets off ebay, then use the Injector flow bench that i have to pick out the 8 best and matched flowing ones and use them. I know they are rated at 36lb stock, but i've read they flow 33lbs.
Old Apr 9, 2007 | 01:20 PM
mdenz3's Avatar
Anyone?
Old Apr 9, 2007 | 02:07 PM
transAMdriv3r's Avatar
A book at my work says the only injectors that will work for the lt1 are part number 17124248
which are on camaros, firebirds, roadmasters, caprice, corvette ,caddilac fleetwood broughm
Old Apr 9, 2007 | 05:53 PM
turnin20s's Avatar
Thats more than likely wrong IMO I may not be right, but you can use ford injectors and LSX injectors and pretty much any high impendance injector.
I have a set of holley 36# sitting here that I will be using.
Old Apr 9, 2007 | 06:01 PM
mdenz3's Avatar
Those are probably just the stock replacement ones....
I hate it when people post something just for the sake of posting without actaully reading or understanding the thread.
Old Apr 9, 2007 | 09:36 PM
hotrod18_69's Avatar
Yes you can use them. Just flow them out and take the closest 8 to use..
Old Apr 9, 2007 | 09:37 PM
And yes you are right on all of the above...
Old Apr 9, 2007 | 10:16 PM
mdenz3's Avatar
Ok thanks alot for the help hotrod18 69!
Old Apr 9, 2007 | 10:18 PM
You bet!
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
