o2 sensor and header bolts
Old Apr 6, 2007 | 03:37 PM
FAST96Z's Avatar
whats up im about to install pacesetter lts and ory just wondering what should i do with the 02 sensors keep them and get the extensions or get the 02 simulaters and what header bolts do i need for a 96 z28,i know arp but, if anyone has a part # it would be helpful
thanks eric
Old Apr 6, 2007 | 03:59 PM
2000GTP's Avatar
thanks eric
You need the front 02 sensors. You'll have to buy a pair of extensions to lengthen the harnesses. I found the 12" size to work well. You will need 02 simulators or a PCM tune for the rear 02 sensors that are after the cats. Since you are going to an off-road y-pipe without cats, the rear 02s won't be used or needed.
Old Apr 7, 2007 | 08:17 AM
FAST96Z's Avatar
were did you get the extensions and the sims
thanks eric
Old Apr 7, 2007 | 07:57 PM
2000GTP's Avatar
You can get the extensions and sims from Thunder Racing. I think Thunder only sells 24" extensions though. You can get the shorter 12" extensions from Victory Racing Engines though, another supporting vendor.
HectorM52
Jul 30, 2017 11:46 AM
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
