looking at buying 255lph pump.
Old Apr 3, 2007 | 02:03 PM
kline454's Avatar
Anyone know a good place to get one? it for a 1995 camaro,
Old Apr 3, 2007 | 02:14 PM
2000GTP's Avatar
Try the Racetronix pump from Thunder Racing. It'll run around a 140 bucks.
Old Apr 3, 2007 | 03:32 PM
kline454's Avatar
anyone use the holley 255lph pump, what all do you have to do to the sending unit to use a 255 pump?
Old Apr 3, 2007 | 03:37 PM
2000GTP's Avatar
I'm not sure about the Holley pump. The Racetronix pump is a direct drop in, you won't have to do anything to the sending unit.
Old Apr 3, 2007 | 05:56 PM
Mike96z's Avatar
By far the best place, wouldnt go anywhere else. Installed mine, worked fine. If you in TX you could get it $100.00 cash no tax or anything! Great to deal with.
http://autoperformanceengineering.com/
Old Apr 4, 2007 | 09:28 AM
kline454's Avatar
do you have to change your regulator or anything with the walbro pump form autoperformanceengineering.com.
Old Apr 4, 2007 | 10:08 AM
2000GTP's Avatar
The stock regulator should do the job fine in keeping the pressure to spec.
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
