Rear thrust alignment?
Old Mar 16, 2007 | 06:36 PM
GnarlyZ28's Avatar
I was getting my car aligned recently and i noticed the rear thrust was out of specs by about 0.15 degrees.
I was wondering what exactly the rear thrust is, and if it being out of specs may be an issue.
Old Mar 17, 2007 | 02:27 AM
TW95Z's Avatar
one rear wheel is more forward than the other so the rear wants to go a different direction rather than follow directly behind the front wheels.
Do you have adjustable lower control arms?
Old Mar 17, 2007 | 08:37 AM
respectirocz's Avatar
if you dont have adjustable control arms it can be cause by a bent control arm or maybe even a bent panhard rod
if you do have adjustable control arms, adjust both of them till the wheel is centered in the wheel well on either side, that should be good enough
oldschool
Feb 9, 2016 09:21 PM
achipfef
May 5, 2015 10:20 AM
Hurin
Dec 13, 2014 07:38 PM
