Rear Caliper Mounting Bracket Shims
Old Mar 14, 2007 | 11:17 PM
quickmedic1's Avatar
Just a question for those who have installed a 12 bolt. I bought a used 12 bolt and had it redone. It has LS1 brakes on it which is an upgrade for me since mine is a 94 car. Anyway I installed the rotors on it and installed the caliper mounting brackets and found the right bracket contacts the inside face of the rotor. If I install a 1/8" washer between the caliper bracket and the bracket that is mounted to the rearend assy I then have the same distance as what is on the left side.
Is this normal to have to shim the brackets ? I tried to check things side to side but everything looks fine. Any ideas?
Parts Wanted
Mar 17, 2015 11:24 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
Cam's maro
Jan 8, 2015 05:01 AM
FirebirdGT
Dec 13, 2014 10:25 PM
