30# injectors
Old Mar 14, 2007 | 06:24 AM
gillt1's Avatar
Question 30# injectors
HI all,according to my sig would 30# injectors help with any performance gain ? Thanks In advance
Old Mar 14, 2007 | 02:38 PM
2000GTP's Avatar
It depends if your stock injectors are getting towards maxed out on the duty cycle. If they are, then an upgrade would be of benefit.
Old Mar 14, 2007 | 04:56 PM
TobyZ28's Avatar
Your Sig:
95 z28,t-tops,K&n cai,52mmtb,lt4km,lt4cam kit,pacesetters lt,magnaflow,no cats,pcmforless, P&P heads,30# injectors 3.73s and new purchase,1996 m6 , convertible ,k&n cai,52mm tb,air and egr delete,skip shift delete
My Answer:
Car1 - Absolutly not you have them already
Car2 - No, your car is relativly stock
Old Mar 15, 2007 | 06:22 AM
gillt1's Avatar
OOPs 30# injectors should not be in sig for 95z ,MY MISTAKE SORRY ,was going to install,also have aded a 58mm tb Thanks All
Old Mar 15, 2007 | 06:43 AM
SnakeOiler's Avatar
They won't increase hp, if that's what your looking for.
As 2000GTP said, check your duty cycles, if over 80%-85% then the 30lbs might not be a bad idea.
Old Mar 15, 2007 | 12:31 PM
TobyZ28's Avatar
If your car was struggling up top for fuel you would likely feel it. For a heads /cam car it is possible you may get a little bit more up top if this is the case
Old Mar 15, 2007 | 05:40 PM
Denny McLain's Avatar
Personally, I bet money you would get nothing but another bill to reprogram you computer for 30 lb injecters. If you're over 385 to 390 rwhp in a six speed and want to keep the stock fuel pressure, then it's another story.
Spend your money instead on sex, drugs and booze. At least you'll be having a good time while your getting screwed.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
